Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-16-2006, 12:16 PM
NYCEGUY01 NYCEGUY01 is offline
Re: 6.5L Diesel shooting out black smoke
Hey moron , if it wasnt for idiots changing all those "faulty" pumps for no reason they wouldnt have a bad name.
If you think a faulty pump is causing a black smoke condition ( rich= too much fuel) youd better go back to the lawnmowers youre used to working on.
He has a classic boost problem. could be the vac pump or the wastegate, or maybe just a cracked vac line.
This stuff is diesel 101
  #17
Old 12-16-2006, 12:32 PM
dvdmacdaddy dvdmacdaddy is offline
It is not the injection pump!!!!!!!!! Yes they are known to go out mine did after 150,000 miles, when they go out you get spiiting and sputtering, random shutoffs, problems starting. If you have leaky injectors you are going to get alot of smoke when you START the truck. I'd bet EVERYTHING I own on it being related to your turbo. It is either the ECM, wastegate controller, the wastergate vacume pot, or the turbo itself. If you want a real true answer got here. These people know what they are doing.
http://dieselplace.com/forum/forumdisplay.php?f=21
  #18
Old 12-16-2006, 01:06 PM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
I've had problems with pumps causing sputtering, black smoke, starting problems... Never had a comeback saying my diagnosis and repair is innacurate... I've also had trouble with vacuum hoses rotting off on those trucks, and very rarely I've seen turbo problems.. but never black smoke related to a turbo problem
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
  #19
Old 12-16-2006, 01:07 PM
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
  #20
Old 12-16-2006, 02:58 PM
chrisk1500 chrisk1500 is offline
Now who's the wiener (notice the spelling)....
94 Silverado 1500 Z71, 320 000 kms, 6.5 TD (VIN S), 3.73 rear, 4L80-E, high idle switch, snorkel removed, EGR blocked off with 45mm frost plug in tower, ISSPRO boost gauge and pyrometer (pre-turbo), #9 resistor, FSD cooler remote mounted behind bumper, 6' homemade PMD extension harness, 97 cooling upgrades, 10k pot set @ 10 psi boost, gutted upper intake, WAP glow plugs, leaf spring helpers....Saving up for: straight pipe 4" exhaust, intercooler, chip...
  #21
Old 12-16-2006, 03:01 PM
Don't matter much to me!
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
  #22
Old 12-16-2006, 03:02 PM
Wow....you must have worked on all kinds of diesels....hahahaha.....better go back to working on gassers.....you obviously don't have a clue about turbo diesels.....
  #23
Old 12-16-2006, 05:40 PM
jifaire jifaire is offline
For what it's worth ... my truck has almost 300K on the original 5068 pump ... and most GM mechanics will tell you that everybody (including them) changed out about a million Injection Pumps on the 6.5
ONLY
because they didn't know what they were doing at the time.. the big problem with the 6.5 is the electronic driver (PMD) on the pump, and when you change THAT instead of changing out the whole pump, the sputtering/dying/missing issues disappeared.
But that's all irrelevant to this thread, because the problem has nothing to do with injectors or injection pump. You aren't getting enough air, which means your Turbo isn't spooling properly.
I strongly suggest that you check the vacuum pump and lines (should have over 20" between the pump and the Vac solenoid, and at least 15" at the wastegate controller.) If you have less than this, you may need to change either the vacuum pump (no vacuum), or the solenoid (vacuum before solenoid, but not after), hoses (loss of vacuum at any point in the loop), or just go with a mechanical wastegate controller, like I did.
Once you get enough air in with your fuel, the black smoke issue will disappear.
Why isn't the problem injectors? Is it running poorly? White smoke on startup? Is your power balance off?
Why isn't it the pump? Does it run? Is your SES light on? Do you have any codes stored (you can use a paperclip to read the stored codes... if you need help with this, look at http://dieselplace.com/forum/showpos...56&postcount=4 ; put in the paperclip, turn on the key, and watch your SES light flash ... it will flash each code 3 times, like morse code. To clear the codes, push the pedals down like it says
Looking for a mechanical wastegate controller? Well, you can build your own for under $10, but I bought mine because I wanted it right. Check out the 'turbomaster' at Heath Diesel (www.heathdiesel.com)
Get that thing running right, and you'll be in love with your 6.5... you'll kick butt on the 7.3 PSD guy above.
  #24
Old 12-16-2006, 07:27 PM
DavidPhillips DavidPhillips is offline
Hey,
I had the same problem with my 95 6.5 and it had a broken vacuum line from the vacuum pump to the wastgate solenoid on the drivers side valve cover. The plastic lines get brittle from the heat of the engine and age.
It was very easy to fix.
If you are getting vacuum up to the wastegate solenoid with no broken lines look at the vacuum line that goes from the solenoid to the turbo. Check for vacuum there. Unplug it and see if the rod move freely with your hand.
Report your findings.
Injector pump is very expensive compared to a simple vacuum hose. Start with the simple stuff first.
There are some people that will give bad advice on this forum. Be careful if it means buying something before checking to see what's bad.
I have never heard of this problem being an injector pump. It's the last thing I would consider buying. Right after I tried to see if it was low air in the spare tire.
  #25
Old 12-16-2006, 08:39 PM
It's me again.
Had to run for a minute but I thought I would just shed some light on the leaking injector theory.
If an injector is leaking fuel out of it you will get white smoke as the motor starts up due to the fuel that leaked into the cylinder. If it gets really bad you will find diesel in your motor oil. This conditions is refered to as making oil.
Black smoke is produced by extreme heat and lack of air.
Diesel that is just leaking out not burning is going to be white smoke.
If you don't get a lot of white smoke your injectors are not leaking down.
Getting white smoke? Still other things it could be.
  #26
Old 12-18-2006, 11:10 PM
Once you check the intake air supply and turbo with this kind of problem you need to move on to the exhaust system and check for a restriction there.
  #27
Old 12-19-2006, 08:12 PM
heres what mitchell says
"obstructed air intake to turbo"
"obstructed air outlet duct from compressor"
"obstructed intake manifold"
"air leak in duct from compressor to engine"
"air leak at intake manifold to engine joint"
"obstruction in exhaust manifold"
"obstruction in exhaust system"
"gas leak in exhaust manifold to engine joint"
"gas leak in turbine inlet to exhaust manifold joint"
"Engine cam timing incorrect"
"worn engine rings or liners"
"internal engine problems"
"dirt caked on compressor wheel and/or diffused vanes"
"damadged turbocharger"
If theres excessive noise like the ones I work on
"incorrect pump timing"
"incorrect pump pressure"
"internal leaks"
"defective pump"
"engine coolant temp sensor reading is 5 degrees greater or less than temperature on cold engine"
I have a list of corrective repairs as well as proceedures if you need them let me know and I'll send them
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
  #28
Old 12-19-2006, 10:26 PM
Seems Mitchells disagrees with you then....
  #29
Old 12-20-2006, 08:19 AM
Doesn't mean they don't happen, just saying I've never had one...
I always get a chattering sound, sputtering and black smoke..
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
  #30
Old 12-20-2006, 12:15 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Alright,
This has become a pissing match that is totally uncalled for.
Go back to your corners..the fight is over and the thread is closed
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Closed Thread
