Old 10-05-2006, 12:01 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Crankwalk cause
lol then i would expect it to not have walked yet with 0 miles...
Old 10-05-2006, 03:52 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Crankwalk cause
I ment my end play is within specs :P
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 10-05-2006, 10:29 PM
SLoe's Avatar
SLoe SLoe is offline
Re: Crankwalk cause
Originally Posted by NOFX0617
From what I have read lately the 2g oil squirters suck...and get clogged really easily...or also the oil pump is clogged and you dont get enough oil pressure...have you read the write up on Magnus Motorsports...that was the most in depth article that I have read on the subject....here is the link... http://www.magnusmotorsports.com/tech/crankwalk.htm
That theory is not that the squirters get clogged(that would be fine), but that they get stuck open and lower oil pressure sufficiently. So when you are sitting at the light at idle with your foot on the clutch, all your oil is going to your squirters instead of your bearing surface and the pressure of the clutch on the flywheel causes the crank to ride against the bearing. So with low oil pressure at idle and pressure from disengaging the clutch you wear it down.
I believe the cranks are not hardened deeply enough, and if someone were to send one off to be nitrided, they would never experience "CW" again.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-05-2006, 11:58 PM
blk_srt's Avatar
Re: Crankwalk cause
I know with my crank all the wear was on the bearing the crank had little to no damage and just got a polish and it was perfect
Mods:
Old 10-06-2006, 02:33 AM
SLoe's Avatar
Re: Crankwalk cause
UMMMMM.......Maybe I put that badly. You will not ruin the crank if it is nitrided, only the bearing, and/or block. My crank was totally ruined when I walked. Not just the bearing journals, but the crank was eaten up into the counterweight.
OOOPS!
Old 10-06-2006, 08:22 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Crankwalk cause
I have also read alot on the cranks not being hardend deep enough, calling them inferior. I have seen some cranks worn and not the thrust bearing.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 10-06-2006, 09:29 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Crankwalk cause
Well, most would agree... crankwalk isn't caused by one problem; or it would have been found. The problem stems from multiple causes...
Someone needs to take and nitride their crank, remove/block the oil squirters, disable the clutch switch, replace the bearings (even upgrade them)... and drive the car... checking the tolerances at set intervals, say 3k, 6k, 15k, 30k, 60k, 100k, 120k, 150k... see if the car crankwalks... report the results... and if it works, everyone (w/a 2g) follow their recommendations... and voila...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
