Old 10-01-2006, 04:38 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: V8 Rumble
damn you!
my stars are purple. i win.
Seatbelts Saved My Life
Old 10-01-2006, 06:03 PM
psychopathicdude's Avatar
psychopathicdude psychopathicdude is offline
Re: V8 Rumble
yes, the lads at Powertec are making V8s as though they were making biscuits....take (2) four-cylinder engines, (1) reverse mounted cylinder head, modified block, custom ground camshafts, custom crankshaft, custom engine management, add fuel, and you have Formula 1 performance at Daimler-Chrysler price! Damn them....I wanted to do it first.
This Space Intentionally Left Blank
Old 10-01-2006, 06:38 PM
534BC 534BC is offline
Re: V8 Rumble
A flat crank definately sounds different. I can't remember the last place I heard one. Do 2 cyclinders fire at same time?
Old 10-01-2006, 07:59 PM
GreyGoose006 GreyGoose006 is offline
Re: V8 Rumble
it has to do with the order the cylinders fire in.
i'm not sure of the order, but it makes a different noise than an 'american' design V-8
Old 10-02-2006, 09:22 AM
Re: V8 Rumble
A normal 90 degree v-8 has 2 cylinders up at same time, going to a flat crank ould have 4 cylinders up at the same time and 2 must be fired at once, sounding like a "pair of inline 4's"
Old 10-02-2006, 10:47 AM
Re: V8 Rumble
isnt that rather inefficient tho?
wouldnt it be better to take two inline 4 cranks and connect them, but rotate one 90*
that way, the firing would be more uniform
Old 10-02-2006, 11:50 AM
Re: V8 Rumble
Yes, I think so. That's probably why all v-8 are 4 different throws on the crank. I can't for the life of me remember what the idea was with going to a flat crank in a v-8, I haven't heard many, but if I remember correctly were in pulling tractors and had a very distinct sound that could not be mistaken, but they never seemed to catch on very well.
Old 10-02-2006, 12:23 PM
Re: V8 Rumble
side to side balance would suck...
Old 10-02-2006, 01:17 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: V8 Rumble
and yet is still there in a ferrari 360 and the V8 in a TVR.
AF's Guidelines
Read them.
Old 10-02-2006, 09:21 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: V8 Rumble
OMG bro I don't know which one of your posts I want for my signature. They're so funny
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 10-02-2006, 09:24 PM
Dyno247365's Avatar
Re: V8 Rumble
A flat crank V8?
Old 10-02-2006, 09:36 PM
Re: V8 Rumble
yup.
Old 10-02-2006, 10:40 PM
Re: V8 Rumble
Don't forget the very different and distinct sound of a V8 with a flat-plane crank. Sounds more like two high-strung 4 cyclinders in harmony. Or four Harleys in a row. No rumble....more of a scream. Odd, to make a V8 sound more like a Hayabusa...but it'll net you better crank balance, higher redlines, and lower reciprocating weight, due to not needing excessive counterweights. I want one.
That's right, I forgot. No big counterweights and no bob weights . The two end pins are lined up right? and the 2 center pins?
Old 10-02-2006, 10:41 PM
UncleBob UncleBob is offline
AF -Advisor
Re: V8 Rumble
exact same crank geometry as an I4, just two con rods per journal instead of one
what would be really interesting would be a big bang V8 in such a config. 1 & 7 would fire at the same time, as would 3 & 5, 2 and 8, 4 & 6
Basically a really big V4 engine
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 10-03-2006, 04:17 PM
Dyno247365's Avatar
Re: V8 Rumble
what pins? gotta picture?
