#16
yeah, tks for yr help man.....appreciate it!!
now, time for modding the truck.............. Quote:
#17
Re: leaking coolant, where is it coming from ?
just to let you guys know that the truck runs great after the repairs!
i paid total of $834.00 for the flwg: -new timing belt -new a/c belt -new cam seals -new idler pulley -new belt tensioner -new water pump -new radiator -new radiator upper and lower hoses -new oil and filter everything is brand spanking new and labor included with that price !!! |
#18
Excellent deal!
What kind of radiator did you get? Also, take a look at your passanger side (up against the firewall) heater core hoses, there should be two - check their condition, they may be at the end of their lifespan. These are a PAIN in the arse to get to, but can be done within two hours or so by the normal every day person - it's just they're hard to reach is all.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
#19
i think i got the oem radiator.
i forgot to check the heater core hoses up against the firewall. i am sure i can change them my myself, right? or is it that complicated ? truck runs good, a/c runs ice cold and im very happy cuz i dont have to worry about these things for the next few years...im hoping. do you know where i can get the stock roof rack? is it expensive from the dealer or do i just buy from ebay ? i plan to get a 3" lift. if i keep my stock wheels, what size of tires shud i get ? i also plan to repaint either black or white and get chrome bumpers and those nerf bars. Quote:
#20
Heater core hoses, yes, you can do those yourself, just hopefully you have small hands - area is REAL tight, that's what makes them a bugger.
My stock OEM rack came with my truck when I bought it - like I said, personally, I wouldn't spend the money for an oem rack unless you can find one for $15 or less; otherwise, it's not worth it. Your stock wheels, are they alloy or steel? 15 or 16"? My truck came with 16x6 steel wheels that I ran 245/75 tires on for years; then recently switched/upgraded to 16x8 wheels and am now running LT265/75 16's with no lift, no rubbing. If you have the alloy wheels, you can run the LT265/75 16's or the 31x10.5 15's, depending on if you have 15 or 16" wheels without rubbing or a lift. After the lift, you can run LT285/75 16's or size equivalent in the 15"s; but beware that the 3.2L V6 is already at a slight disadvantage for the weight of the truck alone - once you add bigger tires, a lift, and accessories, then if you pack up for a weekend adventure, don't expect it to haul down the highway at the same speed as before. I personally wouldn't dream of going bigger then my 32"s, and with the combination of my accessories, i.e. 2 sets of foglights, luggage rack, 32" spare tire, class 3 hitch, 2 fast growing boys, 2 adults, 3 dogs and all of our gear for a typical weekend, and then, if I hook up the 4k# boat, on flat land highway we're fine, but if we hit a good mountain, (I-70 mountains for instance) you can imagine the screaming that comes out from under my hood. Needless to say, the Rodeo doesn't typically haul the boat anymore, didn't want to chance it with higher mileage setting in.
#21
yeah, i will try to do those heater hoses when i have time.
i think i have the 16inch stockers on my passport. so i can use LT 265 / 75 / 16 w/o any rubbing issues? i dont plan on lifting it up yet. i want to restore the exterior first and get it repainted at a cheap price.. nothing fancy, just want to make the truck look decent and all. i do want to change the bumpers to the chrome ones if i paint the truck either white or black. as for the roof rack, yeah.....i will try to find a set from a junkyard or something. i am also looking for cheap nerf bars and a brush guard. |
#22
You can use the LT265's if you have the 16x7 in wheels, at least. I had that size mounted on 16x6 wheels, so it can be done, but they crown horribly and will wear out FAST.
I do not have any kind of lift or modifications to my suspension. The brushguard and nerf bars just make sure you do not leave them on when you start to take the truck off-road, or you'll be replacing doors and the front hood to the engine bay, even possibly a new radiator.
#23
tks ramblin! i will prolly consider the LT265'S then with my setup right now.
you know how much they go for ? any specific place toget those tires for cheap including mount and balance ? Quote:
#24
Discount tire stores are great.
I have the Yokohama A/T tires on 3 different trucks, a set of LT265/75 R16's will probably run you somewhere in the area of $575-$700 range just depending what their prices are in your state.
#25
but WTG in catching this before the engine blows a head gasket... |
#26
i see.....how about american tire depot ? i wonder if they're cheaper...
you guys know what roof rack will fit on my 94 passport other than the exact one ? will 97-up fit my truck ? just curious cuz i can't seem to find any for cheap....for my particular year. Quote:
#27
What kind of rack are you looking for exactly? Stock or aftermarket?
Either or from the 91-97 model years should fit your Rodeo. I've never dealt with American Tire Depot; not sure if there is one here in Colorado.
#28
you just reminded me....it did include the thermostat as well.
just the stock rack i suppose...i think it will be just for looks....
i will keep an eye around ebay... Quote:
