| Off-Topic Talk about anything other than cars. |
#16
Re: Post here every time your "DSM" having problem
broke the accessory belt and some other magic problem that doesn't allow the car to run.
1991 GSX 2.3 Stroker |
#17
Tie rod is shot, gas cover doesn't pop open, pulls to right, clutch is annoyingly low grab, sunroof sometimes leaks when it rains.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
#18
the only problem i have is i always want something else and i dont have the money for it other wise its pretty nice just needs to run 10s and be daily drivin.
1992 eagle talon tsi awd xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit |
#19
its funny, ever since i sold my DSM's i've made money, even with buying the new car i still have money in the bank...
#20
Tada time for my broke ass ride list. In the 6 months I have owned the car the following broke much of which is fixes.
4 tires went bad in 1 month so new Yokohamas. ISC took a shit and died so new one. Exhaust manifold gasket was fried. Valve cover gasket leaking. Driver door handle broke. Sunroof making aweful noise when driving. Front right axle broke. Brakes all started squiking so new brakes. EGR whatvever broke so it was in a shop for a while. New spark plugs and wires since yesterday (NGKs of course) since spark was jumping wires were old and plugs were destryed. And some damn noise that wont go away when I have headlights or brake lights on it keeps beeping and driving me crazy. Thats about all the stuff I had to fix in 6 months time. Do I regret buying the car ? , fuck no. I love to see the face of people when I burn off the line and they always go " damn bro , what do you have under the hood ? I always say, lots of problems.
1997 Eclipse GSX |
#21
DSM = Dollar Sucking Machine. i wish my list is as short as yours.
#22
well, I'm new here... but there was an existing list when I bought the car...
cracked valve cover (leaks like a bitch) slightly leaking manifold rough idle (can't find... tested everything) broken motor mount (side mount, broke, other's just worn) 4 Maypop Tires bent stock rims blown stage III clutch clutch pedal out of adjustment flexing rubber intercooler hoses (popped within a week) broken driver's power window I could go on, but that's the biggest things...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
#23
remember back then, when I about to buy my talon, I let u guy saw a clip video of my car ? and most of you guy told me I have exhault leak. Well after couple month I believe u guy, 3 fucking bolt that in my exhault manifold broke, that why I loose so fucking power. my mechanic fix my car, new clutch master cyclinder and new exhault manifold gasket and couple new bolt, now my car run and pull harder then before I love it.
![]() BTW: I washing my car now, and ready to dry and it fucking rains ( yes I do washing my car in the middle of the night, im ready go to spot.)
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold Last edited by Killa; 09-08-2006 at 10:24 PM. |
#24
I won't even bother listing everything I've done to my car in the last 6 months. I don't have the time or the patience to type it all out right now. As for *Current* issues with the beast; List as follows.
** While doing 255hp I messed the float up, so it never drops past 1/4 tank. Lucky enough the fuel light actually works.. ** Rear hatch struts are starting to go bad, as well as the rear hatch lock doesn't like to work a lot. ** Rear power antenna is permanently in the up position. ** 2 of my 4 struts are blown. ** Rear shaft seal connecting my drive shaft to the rear end is leaking.. I need to fix that soon.. ** ABS module is going out, vibrates like a Chinese hooker when I start the car up. ** Sunroof broke early this spring, had to take it apart to get it closed.. ** HVAC lights are not functional due to my PLX hole cutting. ** Boost pressure sender for my Meth Injection failed. Good think I coughed it during a boost leak down test. Actually ordered a new one today.. ** Brakes are going bad (changing tonight) ** Turbo's grenaded (using friends, but installing EvoIII tonight) ** Getting bored, couple other little things...
DSM geek |
#25
my car is stuttering like hell once i give it alot of gas and around 10+ psi....and overall i have power loss, i can feel it!
#26
that was awesome.
Sometimes, after I make a left turn with my blinker light on, the blinker lever doesn't like to pop back to the off position..... hahahaha.
![]() 2006 Wicked White Evo IX GSR 323 awhp / 311 tq. (Dynojet) http://www.projectevoix.com http://www.4WStuning.com 99 RS < 98 GSX < 06 EVO
#28
ok here is my little list
brakes vibrate on highway even after new pads and rotors weird ticking noise i always had(you all know that one) lawnmower sound if i turn my heat/ac/air on past the first notch(real loud) leaky sunroof tirerod bad on drivers side after i just spent money to fix the passenger side one both door handles snapped off(went to ebay $35 for both and 1 1/2 hours to put them in)real pain in the ass rear hatch sticks have to turn key and pull up at same time evap solinoid cell p1494 thats has been on for at least a year...cant seem to fix it ok well there is more but its gettin long so i will end it,there ya go guys.~joe
2000 GRAND PRIX GTP RED 14.345 @97.8mph ubend delete 3in jimmyC downpipe magnaflow high flow cat Joeflo CIA (made it myself) free bypass mod 3.4 pulley from zzp Gates premium belt 1 step colder plugs zzp PCM ss 409 xl turbo mufflers |
#29
My Talon is in 543565590987321 pieces.
-Brian
#30
My passenger door handle just brake
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
