Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 10-09-2006, 06:48 PM
Larry Renger Larry Renger is offline
Re: '06 Impreza 2.5i Wagon vibration
Interesting you should mention aerodynamics.
First, I came across a guy with a hopped up SPI. He said that a roof spoiler might be the fix.
Second, it was chilly here (oooooh! 60 deg) in the morning and the shaking didn't happen. Two possibilities, first the air would be more dense, and second, the tire pressure drops 1 psi for every 10 deg according to my tire guru.
I have ordered a set of Pirelli tires, and will get them on this weekend. More late breaking news as it happens!
Old 10-09-2006, 07:32 PM
freakray freakray is offline
AF Modelrater
I don't see how it can be an aerodynamic issue - my WRX Wagon doesn't shake.
The roof spoiler a fix? Is he referring to the Wagon roof spoiler or the roof spoiler on his STI?
If he's talking about his STI, I just hope he understands the function of the roof vane.
On the Wagon, I can't say I notice much difference that it makes.
AF User Guidelines
Old 10-09-2006, 07:46 PM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
I do notice that the roof spoiler makes my wagon look faster, and that's worth 10hp right there!
I was thinking that the aero of the '06 was really the only thing significantly different from the '04, that's why I threw that out there. Also, 1psi shouldn't cause a vibration (nor should 4 or 5). Especially if you've had the tires balanced, since they're supposed to check the air pressure before they balance.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 10-10-2006, 10:08 PM
AF Modelrater
Originally Posted by SabreKhan
I was thinking that the aero of the '06 was really the only thing significantly different from the '04.
Please tell me I didn't actually read that
What about the different turbo, engine, suspension, transmission, wheels, brakes.....I can keep going.
AF User Guidelines
Old 10-11-2006, 09:09 AM
SabreKhan's Avatar
I just assumed the 2.5 N/A was relatively the same as the 2.5 N/A from last year. Have they really upgraded all that much stuff? (I know they didn't put a turbo on it, and we've already discussed the wheels).
2000 Saturn SL
Old 10-11-2006, 09:33 AM
SabreKhan's Avatar
After further research, it turns out that Subaru also changed the valve timing on the N/A motors and re-routed the exhaust a little... still nothing that would cause a vibration based on mph.
2000 Saturn SL
Old 10-11-2006, 09:23 PM
AF Modelrater
Blah, yeah, no turbo...we can only wish
AF User Guidelines
Old 10-12-2006, 10:56 AM
In the parking lot at work, I noticed the Saab version of my wagon. It does have an overhanging lip from the top of the roof which would give a cleaner air "break" over the top. Should be much smaller vorticies than the smooth curve of my car. Hmmmm!
BTW what is N/A with regard to the engine?
Old 10-12-2006, 12:53 PM
SabreKhan's Avatar
Naturally Aspirated, as opposed to Forced Induction (superchargers and turbochargers).
2000 Saturn SL
Old 10-13-2006, 03:50 PM
You know, it is kind of funny that the 2nd car I tested had the same vibration, but nobody else seems to have ever noticed it. You would think SOMEBODY else would have complained.
Even my wife finally could feel the vibration once I turned it on and off a few times by changing speed. Very strange.
Maybe it's the hemorroids increasing my sensitivity?
Old 10-14-2006, 01:38 PM
New tires, problem solved! I got a set of Pirelli Nero Zero M+S rubber installed, and the shake is gone. Anybody need a set of Potenzas? Cheap!
Old 10-14-2006, 02:16 PM
Jay! Jay! is offline
Horizontally Opposed
Hahaha! That's completely retarded, but I'm glad to hear your problem is fixed.
Hierarchy of Subaru:
(Click to see mine!)
Old 10-15-2006, 11:18 AM
AF Modelrater
The curse of the Bridgestone Potenza RE92 strikes again.....
Smart move to get rid of them.
AF User Guidelines
Old 10-16-2006, 09:32 AM
SabreKhan's Avatar
RE92's were great tires for learning to autocross my WRX. They were grippy enough to use the AWD correctly, slippery enough to teach me the car's weaknesses, and crappy enough that I didn't mind burning them to the ground.
2000 Saturn SL
