Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-26-2006, 09:13 PM
bcook's Avatar
bcook bcook is offline
Send a message via AIM to bcook
Re: What Are Signs Of Misfiring?
I think I may have found a way to reproduce the problem. Gonna try it some more tomorrow. It seems to happen when I try to accelerate(with a gentle pressure on the pedal) from a steady speed while going up hills. Tallahassee is a hilly place so I got a lot of places to try tomorrow.
Old 08-27-2006, 03:40 AM
bigd2006 bigd2006 is offline
hey i have a 2001 monte carlo ss with the v6. i seem to have the same problem except it happens between 20mph-45mph i feel it happens when the car shifts but im not sure i went to schucks and i poulled up a code 7402 or something with t he transmission. my cars symptoms are the same bogs up and shakes my engine and if u push down on gas it will slowly continue. if u find anything out please gimme advice.
Old 08-28-2006, 06:43 PM
bcook's Avatar
Still haven't reproduced the problem yet. I'm about at 3/4 of a tank so it may be a minute before I run out all the 93.
Question. What causes oil to come off of the K&N filter? Just regular use?
Old 09-09-2006, 09:27 AM
bcook's Avatar
I've been reading around. I believe what I had been experiencing was a surge. My symptoms were very similar to those posted in this thread about a Regal. http://www.automotiveforums.com/vbul...d.php?t=590602
I haven't experienced the problem lately. I haven't been up many hills either. I have moved down to 89 octane as well. I am going to change the fuel filter ASAP as well, I'm just waiting on my refund checks to come in.
If it is a engine surge what should I do?
Old 09-10-2006, 12:44 PM
BNaylor's Avatar
BNaylor BNaylor is offline
On a 4T65E tranny the P0742 DTC you are getting is of concern. The torque convertor clutch (TCC) is stuck on indicating you have a valve body related problem. Possibly the TCC-PWM solenoid. This DTC is a type A fault code and stored in PCM memory for retieval. It will disable shift adapts and commands the TCC on at maximum capacity. It is consistent with the bogging and shaking effect you are getting.
Timeslip 08/12/06
AF Community Guidelines
