Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-23-2006, 06:56 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Drove a weak GSX
The reason it's so slow is because the turbo probably isn't even building pressure, so you're basically driving a turbo car, without the turbo. That's why it feels slower than stock. If he hasn't upgraded the fuel pump or injectors yet, you definitely need to do that, and also get a logging device set up ASAP before you boost at all. Depending on exactly what model of T4 it is, that could put down some pretty good numbers. Like crunchy said, 6 psi isn't even on the compressor map, it's too big of a turbo to be runnning a mere 6 psi and be anything efficient. You'll also want to upgrade that BOV too eventually.
95 Talon TSI AWD
97 Eclipse GST
