Originally Posted by muddog321
Flex hose extension that snaps on the end but some of the 90 deg zerks are slightly cocked off center so you may have to use a small open end and rotate it to align for a good fit. Always a pain but always worth it - seems like the lower was an after thought on the 4wds - the 2wds are much larger due to no CV axle.
Right on Muddog. I have a bad zerk that is plugged solid. I tried to replace it but the replacement was a different thread size. Sooooo, when I'm greasing the joints, I take a good zerk off of the other side (after I greased it, of course) and swap it with the bad one, and then grease that second joint. The next time I do a grease job, I swap it back. One of these days I gotta get a zerk from the Dealership, but this works in a pinch. Never let your joints/fittings go without grease, and as you can see here, a plugged zerk is no excuse. Blazee or BLT please post the thread showing the 11 grease joints again, it is too good.
