Old 01-27-2003, 05:33 PM
acunda's Avatar
acunda acunda is offline
thanx Pman for the post!! great stuff!!
Old 01-27-2003, 07:03 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
YEH for P-man......
i think you should make a book on "how to MODEL" .... it would be a best-seller!
man... i did what was instructed and now my DC5 is very shiny...
thnx alot!!!
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 01-28-2003, 04:22 AM
primera man's Avatar
"P-Man"
Originally posted by endlesskev86
YEH for P-man......
thnx alot!!!
Glad to hear it work out O.K
View All My Models Here.
Old 01-30-2003, 04:28 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Thanks for the Tutorial P-Man! When you put it in the microwave, how do you fit it in with it on the stand? and when you go to take it off the stand, wont you get all fingerprints on it? Thanks.
Old 01-31-2003, 02:38 AM
"P-Man"
I have a older type microwave that is alot bigger then the modern new ones
Old 01-31-2003, 04:20 AM
hermanchauw hermanchauw is offline
Thumbs up
Thanks Pman for the tips.
Beginner in car modelling
Currently working on:
Academy 1:35 Hummer, semi-scratchbuilt rollcage, scratchbuilt seat(s), scratchbuilt dashboard, Civic Sir2 wheels (22inch), smoothened body, radiator exhaust vent...
Old 02-04-2003, 03:40 PM
Jedi801 Jedi801 is offline
I just tried this out on my Opel and it looks pretty good. I'll try and post a pic later.
What do you do when dealing with decals? do you put clear over the decals and then polish?
-= Nick =-
'04 VW R32T
Old 02-04-2003, 05:15 PM
Heh, i wouldn't leave it in the micro for too long, it could melt!
Old 02-04-2003, 11:34 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
One last helpful post....
To add an extra step, if you get fingerprints on the body before you paint or you want to make sure no hard-water, or other residue is left on the body use this....
Final rinse with distilled water so it dries clean. This removes all oils as well!!
Good luck!
Russ
My AF Classic Model Car Gallery
Old 02-04-2003, 11:43 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Re: Another......"HOW TO" prepare a body for primming and painting
[i]Make sure you sand the car well...removing molding lines etc. Finish off with 1200 grit paper.
Just wondering what grit you start off with?
Old 02-05-2003, 03:03 AM
"P-Man"
Re: Re: Another......"HOW TO" prepare a body for primming and painting
Start with 600 on the molding lines only, then 800 on them again.
Then do the whole car in 1200 grit
Old 02-05-2003, 03:56 AM
Purpura Delujo Purpura Delujo is offline
That is a great guide Pman, but one question. Do you think it would work with, graffiti spray cans? I've done some research and figured that graf cans are better for models. 500ml for the same price as 300ml of Tamiya, you can also attach different types of caps to get a different effect on applying paint. Example, If I use a "fat cap" I can go through the whole tin in less then a minute. if I used a fat cap I could spray the whole car in less then 2 seconds I'll try it and let you know how I go. Yet another question though, do you use the sandpapper on the whole body to make the body have a very light texture? In other words make it more rough and less glossy then the plastic.
Old 02-05-2003, 09:19 AM
Graffiti paint? Is that what they call Krylon now? =]
Pman what do you do when dealing with decals?
-= Nick =-
'04 VW R32T
Old 02-05-2003, 03:13 PM
"P-Man"
First off...i'd give the paint a miss ....IT WILL END UP AS ONE BIG PAINT RUN I.M.O
Correct about the sanding....it sound almost be as smooth as when you first started but no gloss. The primer will then give it a baby's bottom finish
Jedi801....have a look in the FAQ...it's all in there
Old 02-05-2003, 03:34 PM
Maybe I'm retarded I didn't see it in the FAQ. I saw the section on polishing and the section on decals but not on polishing over decals.
-= Nick =-
'04 VW R32T
Who has the link for the "how to" on replacing plugs and wires ZR800 Sebring | Sebring Coupe | Convertible 3 05-12-2006 12:01 PM
Body Dmage repair and Paint. Need Info Please !!! djstorman '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 11-04-2004 06:34 PM
"How to" make a spinning paint stand Renegade Car Modeling 12 05-09-2004 04:11 PM
81' zx for sale & 280zx seat swap "how to" JDan 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 01-12-2004 03:36 PM
Body Kit Install and Paint costs....? Icemaster Exterior | bodykits | Lighting 2 06-20-2003 07:33 PM
