Old 08-15-2002, 09:09 PM
strodda strodda is offline
Originally posted by luti
Flywheels are located after the engine but before the transmission (at least in a manual). The pulleys are turned by belts coming of the crank shaft. They control the air conditioning, power steering and alternator.
thanks.
also i know they talk about gaining hp by getting rid of the "parasitic" affects, so does that mean that ill gain hp, but lose power in my a/c and powersteering??
does anyone have the aem pulley kit for a 4th gen accord?? is it a 1 or 2 pulley kit? and pics if any
Old 08-16-2002, 08:47 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
yes.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 08-16-2002, 02:05 PM
delsolsi delsolsi is offline
Re: speed and power secrets
Originally posted by white97ex
ok. i'm looking for some tricks to get more speed out of my car or power out of the motor. lets say under 50 bucks. or maybe 100. not massive gains just little ones. change a sensor here turn a screw there....any thing. anyone got something?
I've got two and there both free.
1. Remove you power steering belt, same concept as underdrive pulleys but instead of lowering parasitic drag from all you components you are eliminating it from one. This will increase you stearing effort, but personally I think the stock stearing effort is to soft, so I like it better with out the power stearing.
2. Advance your timing a couple of degrees. You must use 92 octane if you do this.
I've done this on two cars, a '95 Delsol si, and a '96 Integra se. On the delsol I did this after intake, exhaust, and vtech controller. This made nice difference especially in the mid and lower RPM ranges. These are the only engine mods I did on the Integra. It made a big difference, felt like more than intake and exhaust on the Delsol, and I went from averageing 27 miles per gallon to averaging 30 miles per gallon.
Old 08-16-2002, 05:46 PM
Re: Re: speed and power secrets
if i take off the p.s. belt, is there something else with the powersteering i should unlplug so the pulleys arent running for no reason?
Old 08-16-2002, 08:25 PM
Re: Re: Re: speed and power secrets
The power steering belt goes from the crank pulley were your other belts are to the power steering pump. So after you remove the belt your power steering pump is no longer turning, your crank pulley is still turning your other accesories. You can drain the power steering fluid from your rack to make the effort easier, but I don't think this is a good idea as your power steering fluid also acts as a lubricant.
I don't think this will be different on your accord but it might be, just have a look under the hood and check things out.
Old 08-16-2002, 10:34 PM
ok.
is the belt that goes around the alternator the main(crank) pulley youre talking about? i dont really know a damn thing about the belts. if i got a pic would you know which belts are which?
thanx
Old 08-16-2002, 11:10 PM
thanx
Yeah if you take a pic I might be able to point it out. I'm not familiar with Accords but I daught their any different than the other Honda's.
Old 08-17-2002, 12:53 AM
cool, heres a couple diagrams. im not sure if its from the same year as mine, but it seems similar.
ill try to get my lazy ass up and take of real pic of my car if thatll help any
Old 08-17-2002, 12:57 AM
and also, is that crank pulley the same thing as an underdrive pulley?
like this??
i have an a/t, so im not sure what parts are only for manual. but if i can use it id like to get it
Old 08-17-2002, 01:23 AM
The top diagram is of the power steering pump, thats the belt I'm talking about. I'm not sure how it is on an Accord, but on Civic's and Integra's that belt just drives the power steering so removing it doesn't affect the AC or alternator. I'm assuming you got these pics from a manual, just follow the directions for replacing the power steering belt, but skip the part about putting the new belt on.
If you do this mod let me know how it turns out.
Old 08-17-2002, 01:24 AM
like this??
Yes this looks like the crank pulley.
02 Town and Country Lmt, FWD - Clunking from front end and power door problems confused81 Caravan | Voyager 12 08-06-2010 10:19 PM
Lock, and power seat problems!!!! Jefferscene Taurus | Taurus Wagon 12 01-20-2010 02:00 PM
Losing speed and power wraith05 SC/SL/SW 9 01-05-2008 03:29 PM
Speed and Power Koran Engineering/ Technical 4 12-14-2001 02:34 PM
