Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-07-2006, 11:18 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Jimmy SLE died while driving and now won't start
Originally Posted by 95GMCJimmySLE
oh, I'm sorry. I misunderstood what you were saying, I appolagize for that.
The 8th digit in the VIN is a W.
I appreciate you sending me that wiring PDF.
I have both a good multimeter and a 12v test light.
I plan to test at the prime wire and then again at the fuel pump connection to make sure I have power and ground before I do anything with the fuel pump. If both check good, then I'll go ahead and replace the pump.
I should be able to update on the progress later this afternoon/evening after I get over there and do the tests. I'll let you know what I find out.
Thanks!!
You are welcome.
It is in the mail. If you do not get it or cannot open or read it let me know.
Good Luck. MT
MT
  #17
Old 07-07-2006, 11:35 AM
95GMCJimmySLE 95GMCJimmySLE is offline
Great, Thanks!
I got it and printed it out. Looks good.
Quick question to make sure I'm reading this right.
The fuel pump is on a 20A fuse right? I just want to make sure before I go to Radio Shack to get the fuse holder and fuse to make that jumper wire.
Ah, another question, not about that PDF though.
I tried the other day to get to the relays in the glove box but couldn't get the cover off. I had pulled up on the two tabs on the bottom then tried pulling out on the cover but it wouldn't budge. Is there something I'm missing?
Thanks!!
  #18
Old 07-07-2006, 11:58 AM
MT-2500's Avatar
AF - Advisor
Great, Thanks!
Thanks!!
The fuel pump should not pull over 10 amps.
But a 20 amp fuse or circuit breaker is good. The fuse is just for saftey in case of a short someplace.
I always us a circuit breaker to save on fuses but either one will work.
On the cover give it another try or there may be a hidden tab.
They do not make it easy.
Also check both sides of your fuel pump fuse for 12 volts.
Good luck MT
MT
  #19
Old 07-07-2006, 12:04 PM
ah, a circuit breaker, thats a good idea. I'll see if Radio Shack has anything for a good price.
hmm... no they don't do they, make it easy that is. ok, I'll just try it again.
Thanks
  #20
Old 07-07-2006, 12:09 PM
ok, just so I'm clear on this one... I just take the ends of each probe and put them into each side of the fuse to check for the volts right?
  #21
Old 07-07-2006, 01:11 PM
MT-2500's Avatar
AF - Advisor
Not unless you are checking ohms.
With a volt meter you ground the neg probe. And use the positive prove to check for voltage.
On a fuse check both sides with the positive probe for voltage.
And if all else fails read the instructions that came wit the volt/ohm meter.
MT
MT
  #22
Old 07-07-2006, 01:39 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 95 Jimmy SLE died while driving and now won't start
One quick note here, a brass drift punch should be used to avoid any sparks!!
  #23
Old 07-07-2006, 01:45 PM
MT
ah, ok.
Thanks
  #24
Old 07-07-2006, 01:46 PM
Good point, I'll have to find one.
Thanks
  #25
Old 07-07-2006, 06:06 PM
DelCoch's Avatar
DelCoch DelCoch is offline
. . . I'll be sure to check that pulsator as well. What exactly should I be looking for on it anyway? Is it a good idea to replace it while I'm in there just to be safe or is it not a common thing to fail? AutoZone has a AC Delco pulsator in-stock for 20.99 If I don't have the pulsator and just the rubber tubing like you said, do I need to do anything?
The Bosch fuel pump doesn't use a pulsator, as it's not needed. Read the instructions that can with your Bosch pump.
Bosch style turbine pumps provide a steady stream of fuel as opposed to older georotor or roller-cell type fuel pumps that provide fuel in high speed pulses. Output from a turbine is smooth, consistent and high volume + pressure. The little black high pressure fuel line that came in the Bosch kit replaces the bulbous, brass and plastic press-fit pulsator unit.
  #26
Old 07-07-2006, 07:24 PM
ok, I'm trying to check for power at the pump as we speak. I checked the black wire and it looks good but no power on the gray wire like you guys are saying. There are three wires going to the pump... Black, Pink(ish) and Gray. I can't get any volts to read on the gray wire but I get a volt reading on the Pink wire. Is the Pink wire the one I'm supposed to be checking? What is the pink wire for? Please let me know asap because I'd like to get this part figured out tonight before we lose light.
Thanks
  #27
Old 07-07-2006, 07:31 PM
DelCoch's Avatar
On the '95 there is a fuel pump test wire under the hood on the driver’s side next to the fender, under the hood hinge. It’s a red wire that has a gray plastic cover on the end of it and it just hangs there next to the electrical junction box. Put a live 12 volt jumper wire to it and the fuel pump will run if it's not toast.
Have you tried the above??
  #28
Old 07-07-2006, 07:43 PM
yeah but nothing happened. Maybe I didn't have it in there all the way or have a good connection but nothing happened thats why I went to the connection at the fuel pump under the car to make sure it was getting power. But thats where I got confused because everyone is saying the gray wire is power but the gray wire isn't showing power. The pink wire is however getting volts and noone said anything about a pinkish colored wire being there. Just like in the pictures you posted earlier, that purple/pink (or whatever color it is) color wire.
Thanks
  #29
Old 07-07-2006, 07:46 PM
DelCoch's Avatar
Stand by a couple minutes and let me get my trouble shooting repair manual out.
  #30
Old 07-07-2006, 07:47 PM
ok
Thanks
Closed Thread
