Old 06-28-2006, 02:34 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: ok new problems.
damn my bad. i should really check these things. should i just have a shop check it out and tune it or just get the voltage down to the correct numbers than forget the code
Old 06-28-2006, 02:48 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
if you can get a multimeter and adjust it to the right spot...then you will be good and you can reset the code and it will be gone.
But, i don't know of any shop that are going to be able to test it....they usually don't go into electrical like that. If your car is a 1st gen B16a, then you can just get a used b18a throttle body because it's the same size. If not, you can upgrade any other bseries throttle body because they are bigger.
Try not to touch the TPS unless you know how to tune it.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-28-2006, 03:32 AM
2poor2tune's Avatar
well the shop i go to did the testing on my friends. they have lots for swaps that show up with bad ones. i will just get it down with my dads multimeter and then reset it. then move on to the next one. i think i will worrrie about the electrical load next. grounds right?
Old 06-28-2006, 12:21 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Be careful about running your engine without suitable grounds. You could actually burn out all your engine sensors this way. Since the engine tries to search for grounds it goes to the sensors and causes them to burn out. This is what a tech at a honda dealer told me after i broke my valve cover ground. He told me to not even crank the engine without a tranny, VC, or thermo ground. This could be one of the major reasons your engine is running like ass...happened to me too.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 06-28-2006, 03:07 PM
2poor2tune's Avatar
ok i will do the ground thing now, thanks
