Old 06-19-2006, 08:20 AM
Labatt Labatt is offline
Re: fuel pressure regulator 2001 5.3
Yes when i changed the regulator the truck starts and runs 100% better. Before I changed the regulator the truck was hard to start. Roll over and over and I had to press the gas in abit before it would start. Now fires right up. Quick easy fix.
Labatt
Old 06-19-2006, 11:22 AM
justinp01 justinp01 is offline
Well I've only had the truck for the last year and it has a paper filter in it now and when I got it.
It looks to me like no one ever changed the pvc valve and that gave the TB alot of buildup.
Old 06-19-2006, 04:31 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
I havent checked the PCV valve.
Where might I find this valve on a 5.3 V8 (2001 SIlverado)??
Thanks
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 06-22-2006, 10:52 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
I bought an aftermarket Fuel Regulator for $60. I got the worst gas milage, so I replaced it with a OEM for $100 and my millage was increased significantly. There are a differance in the regulator. I normally do not do Factory replacements, but in this case it was better than the aftermarket version.
I believe the PCV valve is on top on the manifold (however I am not sure). You should see a hose going to it.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 06-22-2006, 11:31 AM
The PVC is on the drivers side, all the way in the back, I believe on top of the valve cover. I was told to replace it every 10-15k miles, same with the fuel filter if not sooner.
Old 07-02-2011, 10:47 PM
dmkdjk dmkdjk is offline
Im currently working on my dads 01 5.3 silverado and i changed the plugs wires and fuel filt it runs great untill it gets warmed up but then it falls flat on its face it never dies but barely runs. should i try to replace the regulator or the fuel pump? also what is the spec for the fuel pres on the 5.3L autozone couldnt tell me. any help would be greatly appreciated
Old 07-04-2011, 12:33 PM
2000CAYukon 2000CAYukon is offline
You should probably start a new post for your problem. Fuel pressure specs are 53 - 65 PSI. If is falls flat after it gets warmed up, you need to see what the ECT (engine coolant temp) sensor is reporting. Do you have access to a scan tool? If you pull off the vacuum hose to the FPR, is there fuel in the vacuum hose?
//2000CAYukon
Old 07-04-2011, 01:03 PM
j cAT j cAT is offline
checking the fuel pressure with a pressure guage, and replacing the fuel filter every 30-40,ooomi ,,,,.
with loss of power after warm up this gets into intake/vecuum leaks,damaged/plugged cat converter,muffler system..
egr operation ,other components.. after the fuel pressure testing check for the DTC failure codes post back what found... this vehicle reports most every little failure...........
Old 07-08-2011, 12:42 AM
4x4junkie 4x4junkie is offline
I have 180k on my 6.0L all ive done to it to keep it running right is keep the TB clean, change plugs, change wires, oil changes, and keep fluids changed in differentials, transfer case and tranny..... the motor still runs like it did new other than the piston slap when first startyed after sitting long enough to cool down but that goes away in 30 - 90 seconds..... I have never allowed it to get under 1/4 tank gas... gets 16 mpg average and does have a K&N filter ........ finally had front wheel bearing fail on drivers side this week ....... and my truck idles at 500 rpm and always has....
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
