Old 06-12-2006, 10:00 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: Plenum leak
Originally Posted by troy1
are you going to take it to a machine shop?
I'm still debating that as I'm not familiar with a good machine shop. How much did it cost you for that service? Did they do both sides and shouldn't the head be checked too. I don't think mine ran very hot but who knows.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 06-13-2006, 12:55 PM
troy1 troy1 is offline
AF -Advisor
Re: Plenum leak
It ran me $70 tax included. The heads are such a big chunk of cast I wouldn't bother. If your intake is junk they you might consider checking the heads in a worse case situation
Old 06-14-2006, 10:24 PM
wlkjr's Avatar
Re: Plenum leak
Update Day 4:
Installed LIM, UIM, throttle body, and assorted brackets. Cleaned injectors and replaced half the O-rings. Hopefully tomorrow I can get the injectors, tensioner, new hoses, repaired radiator, fans, and the rest of the story.
I've pretty much been taking my time and replacing everything that might be a trouble spot. I have some before and after cleanup pictures too.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 06:07 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Plenum leak
Keep soldiering Wally, you're getting there, and taking you time is the best way to do it.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-15-2006, 06:09 AM
wlkjr's Avatar
Re: Plenum leak
Six of my injector o-rings were the wrong size though. Everything else is fine. I hope these extra o-rings don't go somewhere.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-16-2006, 07:31 AM
wlkjr's Avatar
Re: Plenum leak
Worked until 2:00am and got everything back together. Dang thing actually cranked and runs with no apparent codes set. Amazing. I do have a leak around the thermostat as I didn't find the new gasket until I had put the old one back on. So I"ll have to lick that calf over. My daughter came over about 9:30 for moral support and ended up reinstalling some brackets and hooked up some of the connectors and hoses. She's a real trooper and pretty knowledgable about car engines. She was about as greasy as I was. Thanks to all who helped especially Bob and Rich. I have a few pics I'd like to share later and will give a rundown on everything replaced and cost for the entire project.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-16-2006, 08:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Plenum leak
You are welcome. Good job and I am proud of you.
Timeslip 08/12/06
AF Community Guidelines
Old 06-16-2006, 06:20 PM
wlkjr's Avatar
Re: Plenum leak
I pronounce my repair job successful. After replacing the leaky thermostat gasket about an hour ago and driving about 15 miles, I can find no leaks. It's up on the ramps now for an oil change after a brief cooling period. Seems to be running cooler than it has in the last year, even though the temps are in the 90's here. Later tonight I'm going to tally up the total cost and parts and post that. But after the oil change I'm going to take a well deserved relaxing time in the pool.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-16-2006, 10:34 PM
AF -Advisor
Re: Plenum leak
NICE!
Old 06-17-2006, 06:08 AM
richtazz's Avatar
Re: Plenum leak
Wally, congratulations on getting it done, and you are welcome. Give me a call at work on Monday, and I'll either send you the proper o-ring kit or give you a credit for the o-rings you had to buy due to the wrong ones being in the intake kit. I apologize for your inconvenience on that one, but I want to make it right.
Old 06-17-2006, 08:17 AM
wlkjr's Avatar
Re: Plenum leak
No problem on the o-rings Rich. I know it was just one of those things and it wasn't your fault. Besides, you have already saved me a bunch of money on the wheel hubs and this job too. I really appreciate all the help. I'm sure I'll be calling you again for more parts. I might try to tackle my mother's 3.1 problem later on. Her oil analysis showed some traces of coolant in her 2001 Century last oil change. She has about 52,000 miles on it and just recently made the last payment.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-17-2006, 09:11 AM
BNaylor's Avatar
Re: Plenum leak
You are in luck again. We have a bunch of expertise on the GM 3.1/3.4 platforms too regardless of the GM make. BTDT. You'll need the revised LIM gaskets. This job is much easier than the 3800. I did an Alero with 3.4L in well under 5 hours from start to finish and that was taking my time. I used only GM/AC Delco repair parts.
BTW - Since you have signs of coolant in the engine do not wait too long. Otherwise possible bearing and piston ring damage and who knows what else.
Here is the applicable GM TSB. In addition to the gaskets, take note that GM revised the torque figures and torqueing sequence of the LIM bolts.
Engine Oil or Coolant Leak (Install New Intake
Manifold Gasket) # 03-06-01-010B - (10/24/2003)
Engine Oil or Coolant Leak (Install New Intake Manifold Gasket)
2000-2003 Buick Century
2002-2003 Buick Rendezvous
1996 Chevrolet Lumina APV
1997-2003 Chevrolet Venture
1999-2001 Chevrolet Lumina
1999-2003 Chevrolet Malibu, Monte Carlo
2000-2003 Chevrolet Impala
1996-2003 Oldsmobile Silhouette
1999 Oldsmobile Cutlass
1999-2003 Oldsmobile Alero
1996-1999 Pontiac Trans Sport
1999-2003 Pontiac Grand Am, Montana
2000-2003 Pontiac Grand Prix
2001-2003 Pontiac Aztek
with 3.1L or 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1)
This bulletin is being revised to change the model Information. Please discard Corporate Bulletin Number 03-06-01-O10A (Section 06 - Engine).
Condition
Some owners may comment on an apparent oil or coolant leak. Additionally, the comments may range from spots on the driveway to having to add fluids.
Cause
Intake manifold may be leaking allowing coolant, oil or both to leak from the engine.
Correction
Install a new design intake manifold gasket. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. When replacing the gasket, the intake manifold bolts must also be replaced and torqued to a revised specification. The new bolts will come with a pre-applied threadlocker on them.
Notice
An oil leak may result if the vertical bolts are not tightened before the diagonal bolts.
Diagonal bolts may require a crows foot to tighten.
Tighten
1. Tighten the vertical lower intake manifold bolts (1) to 7 N.m (62 lb in).
2. Tighten the diagonal lower intake manifold bolts (2) to 7 N.m (62 lb in).
3. Tighten the vertical lower intake manifold bolts (1) to 13 N.m (115 lb in).
4. Tighten the diagonal lower intake manifold bolts (2) to 25 N.m (18 lb ft).
Parts Information
Parts are currently available from GMSPO.
Timeslip 08/12/06
Old 06-17-2006, 09:17 AM
wlkjr's Avatar
Re: Plenum leak
I'm going to check the Buick soon and probably attempt to repair this one too.
Thanks Bob.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
