Old 08-19-2006, 10:14 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Buzzing noise from front end
My drivers side stripped out like that and I went a got a junkyard caliper and rebuilt it...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-21-2006, 08:24 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The caliper isn't threaded, the slide pin that goes into the bracket is. The short bolt that retains the caliper to the bracket actually goes into the end of the slide pin. Is it one of these short bolts (or the hole it goes into) that are stripped? If so, buy a new caliper slide pin and matching caliper bolt and you're set. Did you make sure the long sliders that go into the caliper mount bracket are free and sliding properly when you had it apart? If they are seized, it will cause uneven rapid wear of your brake pads.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-21-2006, 11:34 AM
I just noticed his calipers and slide pins are different than my dual pistons...My slide pin IS the bolt that holds the caliper on..
Old 08-21-2006, 12:27 PM
richtazz's Avatar
You have a pre-97 Grand Prix/W-body, right Corning?
