Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-03-2006, 09:11 PM
TheRomer TheRomer is offline
Re: Cant get over 9psi of boost
I would just do a leak-down test. go to home depot and make yourself one, they are easy. Like kevin said, it would have to be a huge leak, but maybe a leak and something else is contributing to your 9psi. Just rule out any leaks by a leak down, then look into the more difficult things.
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 06-04-2006, 02:34 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Sorry i didn't see this post earlier. Yeah i have the profec e-01. It's on my talon and i haven't used it in a while. Are you sure the "valve unit" is hooked up for an internal wastegate? Also make sure the hole for the external wastegate is closed off. It could be hooked up wrong or a problem with the car not hldin boost for one reason but that was already discussed. You can go to greddy.com for the same manual in pdf it's a little easier to read.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
