Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Interior | Exterior | Appearance
Interior | Exterior | Appearance The place for all interior, exterior and general non-performance modifications.
Old 09-26-2006, 04:03 PM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
Re: 2000 Blazer LT Front Door Speaker Size?
Originally Posted by hodocka
I have to replace the outside mirror on my '95 Blazer and can't figure out how to remove door panel. The screw in the open handle cup is obvious but I don't see the " 2 small bolts under the arm rest" Is this just on newer models? Thanks !
First off try THE SEARCH FUNCTION
Then remove the oval shaped cap with a small flat head screw driver.
Reguarding the op - I put JL XR4's in with custom sheet metal plates. Only took a little time with a jig saw and some patients. As far as the doors, I found that most good aftermarket speakers were too deep anyways. So in the fronts I used JL VR5.25cs with 1/2 mdf adapter rings. In the rear doors I have JLXR6.5cs with the same type of adapter plate made from some 1/2" mdf.
I wouldnt even mess around with trying to find direct replacement speakers. Just use a little ingenuity and put in what you want.
Im running a total of 15 speakers @ 1000 watts. All JL audio
Old 09-26-2006, 06:43 PM
alblogg's Avatar
alblogg alblogg is offline
Did you find the two screws?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 06-20-2010, 09:35 AM
esabis esabis is offline
Just a note about the two bolts "under the armrest" that some folks have been explaining above. Our 2000 Blazer 4D 4WD LS has the rear door panel bolts in a different spot. Looking down at armrest, look inside the the grab handle. You'll see a ~3" long x 1/2"wide cover. Use a small flathead screwdriver to carefully pry up the cover from the rear end. Once the cover pops off, you'll see two 7mm hex head bolts. Remove these. Then follow everyone else's instructions to carefully pry off the door around the edges.
Also note, I had to remove the two trim pieces on the top half of the door before the lower panel could slide up enough to come off. The front trip piece is attached by two small phillips screws that are easily visible. The rear trim piece has the same attachments as the lower door panel. Carefully pry off from the bottom. Once the lower one pops out, you can just swing the trim piece up and out of the way.
The power window button is tricky. Once you get the trim panel off, spin it upside down so that the switch is facing downward. Use a normal sized flathead screwdriver to the pinch (wedge) the silver clasps towards the switch. The switch will pop loose and one of the silver clasps will go flying. Be careful that you don't lose it. Try to keep the other clasp in place so that you can see which direction they go.
My eventual goal was to replace the speakers. There's a GM spaker connector that is tough to disconnect. My best advice after I finally unhooked it is that you have to try and squeeze all four sides at the same time. Good luck.
The speaker had four 5/64 (I think) stardrive screws that had to be removed. Lastly, I have no idea what GM was thinking, but the hardest part is sliding the connector under the housing that holds the speaker in place. The housing is attached to the door by what looks to be four rivets. Dumb design. You'll know what I mean when you see it. Yes, I could have cut the wires, but I was hoping to easily re-use the connector on the new speakers. Nonetheless, I finally used a larger flathead screwdriver to pry the housing away from the door. Eventually the top left rivet-like attachment popped out and the connector slid under the housing easily. Am I going to be able to pop the rivet back in? Will find out later. If not, looks like I can drill out the rivet and use a sheet metal screw.
Hope this helps.
