Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-01-2002, 06:44 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
Originally posted by Dr. Love
Don't bother removing your spare tire or back seat. An extra 50 pounds isn't going to make any noticeable difference in the 1/4 mile.
better than nothing. just think of it as a free mod
Old 08-02-2002, 09:50 AM
Dr. Love Dr. Love is offline
Then go ahead. But I think that the difference in speed will be so insignificant, that it isn't worth the time and effort.
Old 08-04-2002, 11:50 AM
acura2fast acura2fast is offline
Send a message via AIM to acura2fast
hey man i drive a 97 integra LS 5spd 1st time i ever ran it i ran a 16.0 after a whole exhust system and cold air intake i ran a 15.5 and i could beat Stcuk GSRs in quarter mile easly with headers i ran 15.2 , u need to take the stuff in ur trunk out like spare tire , the wooden thing over it , the carpet and the thing behind the back seat that gose up when u open ur trunk. dont bother to take ur back seats off unless u got leder cuz the back sets weights liek 5LBS total, best thing to do is take out ur pasnger seat , make sure if ur car is lowerd front is lower than back and ur gas should be close to EMPTY. LESS WEIGHT IN UR CAR = FASTER UR CAR RUNS.
Old 08-05-2002, 12:47 AM
98integrals 98integrals is offline
wow, acura2fast, you are quite a bit better with your car than i am. This is my first manual, so i'm still getting used to it. Thanks for the advice on the backseat. i hadn't taken it out yet, so i didn't know they were so light.
I will hopefully be going to the track on Friday night, so we'll see how everything goes.
Old 10-25-2003, 03:34 AM
hybridintegrags hybridintegrags is offline
building an ls motor for power
If you want to get more power out of your ls motor there are ways of doing this. Lets just say that if you are really smart about inventing ways of adding more power to your motor then you would be set. Yeah Yeah first things first. Everybody already knows to start with the basic mods Cold air induction, Headers, Cat back exhaust. Now some people don't know to change the Catalytic Converter to a aftermarket converter. Leaving the stock converter makes you lose power. With the cold air induction you want to get AEM's cold air w/ the by pass valve. Dc sports header, Apex cat back exhaust w/ cat. converter. If you are thinking about turbo then you definetly want to build your motor for turbo. Depending on how much boost you are going to push 10lbs of boost or more without building the internals will damage your motor. Rebuild the head and bottom end. Most important part of the motor is the pistons, rods, piston rings, camshafts, cam gears, valves and valve springs. Try to use skunk2, crower, or any titanium internal parts you could find. I did some tweeking to my motor and had a killer integra back in the day. Now I have a 90 to build. The 2000 integra I had was tweeked just right. Lets just say that It was 2000 Acura integra Ls All motor and with a little knowledge in my brain I was able to tweek and run 9.6 in 8th mile at pecan park in florida. That is impressive 9.6 all motor in an 8th mile. I have never seen someone run 17 with a stock ls motor. 14s yes but not 17s. My car basically was stock. no intake, no exhaust, no header, just stock parts. All I did to tweek it was adjust the fuel, ran a computer fan inside the intake real close to the throttle body and ran a hose from behind the seat to the very front of my stock intake for a portable air take full of air which I kept really cold in behind my seat. Works just like nitrous, but without trying to put wear and tear on the motor. After most of the internals are built, get a plug n play mangagement system. Then you want to go with weight reduction. remove as much weight not being used. For instance my car there is only a dash, 2 seats, door panels and the rest was stripped. Hardley any interior. Remove the power steering and the ac. Ac pulls away 35hp from your motor. Power steering I am not sure what hp it takes but it adds a little hp and also with your lowered suspension, turning corners is as easy as pie. if you need to know more ask and I will try to answer. find out the compression ration before adding a turbo. stock compression will not handle turbo over 10lbs of boost and will blow fry your piston rings.
Old 10-25-2003, 12:12 PM
98-integra 98-integra is offline
ok i have a question for you hybridintegrags you removed the a/c and got 35hp? i only ask becuase from i understand the a/c works off a clutch system which only put drag on the motor when it turned on and i dont think that even with it on you would lose 35hp?? im not trying to flame just asking a question
Old 10-25-2003, 05:40 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
a/c pulls away 35 hp? so according to you if i take my a/c out i will gain 140+35=175. hhmmm something is not right here. maybe be it was a typo and what your trying to type was 3-5 hp
Old 10-25-2003, 10:15 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I think the main questio should be Why the hell is a post that is 1 1/2 yrs old revived to post B.S?
Please don't do this in the future this post was as dead as dead can be!
And the air tank working just like nitrous huh? Well is the pressure about 800-1000psi? Does the special air inside it release oxygen at 5xx degrees and increase cylinder pressure and provide the extra oxygen neede to burn more fuel to produce more power? Also the computer fan in the intake Go back to the playground, we should have an age requirement
Old 10-25-2003, 10:19 PM
whtteg's Avatar
Re: building an ls motor for power
Originally Posted by hybridintegrags
..... find out the compression ration before adding a turbo. stock compression will not handle turbo over 10lbs of boost and will blow fry your piston rings.
You mean you and the mad scienetist will have to tear down the motor and replace the piston rings he fried?
Too much F&F
Sorry had to
Old 10-25-2003, 10:51 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Aren't you going to tell us how to make an aftermarket cat? Can't just leave me hangin' like that!
As for the computer fan, I doubt you could fit anything larger than a 60mm chassis fan in there, and some of the most powerful 60mm I've seen only push about 50cfm (yes, take it from a computer geek -- ph33r my 575t3m). I don't that's going to do anything over your stock airflow other than obstruct it. Just leave it stock or get an intake for best results.
And the portable air tank behind your seat? Did you drill a hole through the front firewall or did you run in along the front and under the wheel well? Does your car look like the "Back to the Future" Delorian? I doubt an air tank behind your seat holds enough "nitrous air" to satisfy the motor -- cold air doesn't work like nitrous by far.
And fourthly, please don't dreg up a year-old dead post with crazy-talk. Don't be a TV parrot. Read and understand, don't just post with stuff you've heard.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
