Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 08-22-2001, 04:34 PM
bump909's Avatar
bump909 bump909 is offline
Registered User
first off, that is a really clean looking install.
one thing though, even though you have those fans there.. the heat fins on the amps are facing upside down so any heat that the amps give off will just rise back up into the amp, even with the fans on.
have you ran into any problems yet?
Old 08-22-2001, 07:40 PM
P11GT's Avatar
P11GT P11GT is offline
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
Im aware of what youre thinking but so far, havent run into any such problems. The amps do have a temperature cut-out, but also have a built in fan which pumps out hot air, which in turn will be ventilated with the external fans. It seems to work no problem, even after a good hard thumping of the system.
Old 08-22-2001, 11:29 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
Hey P11, sweet set up. How many watts do you got running through your car right now? do you have caps? if yes, where are they?
Old 08-23-2001, 04:01 AM
P11GT's Avatar
To be honest, i dont really know how many watts, if the amps are anything to go by, then one of the kenwoods is 4x150w at 4 ohms and the other is bridged to 1x400w (4 ohms) but im running the JL at 3ohms. I suppose its not alot of wattage in total but the trick to the system is the Pheonix Gold Bass Cube mounted it the boot, which makes a hell of a difference to the Sub, easily doubling the SPL.
Ive thought about using a cap but theyre quite expensive here, maybe invest in one later. A nice fancy one with a digital readout.
Old 08-23-2001, 08:13 AM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
That is sweet !!!!!
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 08-23-2001, 08:28 AM
Hey, what if you gotta work on the amp? Does that plexi come of easily? Did you run the wires right through the headliner? I still can't believe you put the amps on the roof. That's a really smart setup
Old 08-23-2001, 06:05 PM
aluke000 aluke000 is offline
How is the rack actually attached to the roof? Or are you using cross braces? And does it interfere with the sunroof?
Old 08-23-2001, 08:26 PM
P11GT's Avatar
I'll try to answer all the above questions.
Firstly, i think i mentioned earlier in this thread, or in the 'any ideas on system location' thread, how i was goona attach it to the roof, but basically, the sunroof runs along a suspended rail, fixed to the actual roof. I just screwed bracket onto that and the amp rack.
Secondly, the system has previously been in the car for sometime before. I have the same setup and was quite happy with all the speakers and the sound of the system in general. So i just disconnected all the wiring, left all the settings as before, and just relocated it.
The front does come off. Its made of 6mm MDF and had perspex windows for show, but to be honest, there no room to actually do anything, which is why i left the setting as before as i was happy with them.
I had to make a series of cuts around the lining for the brackets and for the wiring to pass thru, the wires then just come down one side of the rear pillars and into behind the side support and bootrim where all the connections were rejoined.
Old 08-24-2001, 03:03 PM
redvalkrie's Avatar
redvalkrie redvalkrie is offline
Send a message via Yahoo to redvalkrie
Wink
Hey what type of set up besides the amps are your unning Speaker's?
What Headunit?
Any crossover/eq?
(I hear what you are saying but I feel you are lieing to me, would love to say to BUSH!)
"Don't trip, skip, pinch your forehead"!
1988 CRX Si
2001 CBR 600F4i Silver & black FAST!
2004 Toyota Tundra (TRD)
2002 dodge grand caravan.
Old 08-24-2001, 03:10 PM
P11GT's Avatar
The spec for the whole car is listed on www.primeraweb.co.uk , click onto readers cars, kevins'98 GT. Basically, the headunit controls the whole system with its built in electronic x-overs.
Old 08-28-2001, 03:59 AM
Anthony Anthony is offline
And I'll testify that Kevin has a sweet sounding sound system in that Primera, as I had the pleasure of hearing some tunes through it at the weekend.
Just when I was thinking that I had my system sounding alright for a change....
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 10-07-2001, 10:08 AM
P11GT's Avatar
Time for my next project.
I casually went into my local audio shop to ask about this new in dash Kenwood DVD Player, and mentioned that if i got one, i would need one of those Kenwood MiniDisc Slave units, the din size ones. Anyway, as it turns out, they had bought a shit load of them, and because they were last years model, they were selling them for £200 instead of thr RRP £400. The reason why i need a MiniDisc, is because all my music is on them due to my current headunit being the KMD-PS971R, a minidisc player.
Without hesitating, i left a deposit for it, and then went home to think about where i could install it. The ideal location would be in the dash, but as there is little space, and without cutting the dash, i had to find somewhere else.
Guess what, i looked at the front courtesy light housing, where the sunroof switch is, and thought to myself, why not just put it there, that way, its also suspended like the rest of my system. So ive set about making a new housing for the slave unit and this is how far ive got in 3 hours.
UK's 1st Turbo'd Primera GT
Please visit my site www.p11-gt.co.uk Updated 7/3/2003
Some Exterior Mods to go now.
Vote for my car at www.ridejudge.com user name P11GT
VRRRROOOOOOMMM TIIISSSSSSHHHTT!!!
Old 10-07-2001, 10:10 AM
P11GT's Avatar
it still need plenty of shaping, and then covered in black vinyl and finished off with a silver cover like the amp rack.
Old 10-07-2001, 10:11 AM
P11GT's Avatar
because ive used the original light fitting, i can secure it up the original way to hold it in place.
Old 10-07-2001, 10:12 AM
P11GT's Avatar
this is the upright position.
