#16
Re: Summer grade gas
Edit- I am retarded, sorry
#17
NE Ohio has been on summer blend since beginning of May.
What does summer gas mean? |
#18
1995 Factory Blazer Service Manual for sale, PM if interested. |
#19
I wanna say in MA they must have switched within the last week because I am getting better mileage and more power. One funny thing though is the other day I put over 18 gallons in my tank which I did not think was possible. I thought I had an 18 gallon tank and the most I had ever dumped in before was maybe a little under 17. Very odd.
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
#20
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
#21
I thought it was 18 for me? Maybe not
#22
Summer grade gas has nothing to do with alcohol, It has to do with vapor pressure. Butane is added to increase the pressure (in winter) usually and not many can ever tell.
#23
Butane? Isn't that a gas?
#24
Butane is a liquid (under pressure) and a gas at ambiant temp and pressure, like propane only the vapor pressure is less.
I suppose a distinction should be made about the two alcohols and also many different brands will change for various reasons. Methanol is added in winter for fuel line anti-freeze. It way under 1% and will never be noticed for mpg or hp sake. Ethanol is added at (up to) 10% and is used all year round, but may not be used from time to time, but not haveing anything to do with winter/summer. When ethanol blend fuel is used the methanol is not added even in winter. I hear some people claiming lower mileage with ethanol, but I would be hard pressed to be able to tell you the difference if you filled my tank and made me guess which fuel you had used. I think I'd have better luck smelling it than one or two tanks of mpg tests. Theoretically the ethanol blend should have a few % lower mpg and 85% ethanol is claimed to get 10% less mpg. This I do believe,,,, The truth is that over 99% of people probably have no idea what gas they're using and even if they do know, it doesn't make any difference anyways. |
#25
There is a difference in performance noted by several drivers and this is no fairy tale like you are making it out to be. The heating value also varies by grade and by season. On average, the heating value of premium-grade gasoline is about 0.7 percent higher than regular-grade because premium-grade, in general, contains more aromatic hydrocarbons — the class of hydrocarbons with the highest densities. The heating value of winter gasoline is about 1.5 percent lower than summer gasoline because winter gasoline contains more volatile, less dense hydrocarbons. Oxygenated gasolines, which are required in some areas of the U.S, have lower heating values because the heating values of the oxygenate components are lower than those of the hydrocarbons they displace. The percentage decrease in heating value is close to the mass percent oxygen in the gasoline. For example, gasoline in carbon monoxide nonattainment areas must be oxygenated to a minimum of 2.7 mass % oxygen during four or five winter months.6 Footnotes 6 Nonattainment area is an EPA designation for an area where an air pollutant, carbon monoxide in this case, exceeds the limit established by the National Ambient Air Quality Standards more often than allowed. As a result, its heating value is about 2.7 percent lower than conventional gasoline. Federal reformulated gasoline and California Phase 3 reformulated gasoline in federal reformulated gasoline areas must be oxygenated year-round to an average oxygen content of about 2 mass %. As a result, their heating values are about 2 percent lower than that of conventional gasoline. In addition, California Phase 3 reformulated gasoline sets some limits on distillation temperatures and aromatics content, which have the secondary effect of lowering the density of the fuel compared to conventional gasoline. This reduces the heating value by about another 1 percent. http://www.chevron.com/products/prod...rmance/pg4.asp Ethanol has not been the oxygenate of choice for summer RFGs because the volatility increase makes it more difficult to meet the very tight vapor pressure limits of these gasolines. Now, with many RFG areas banning MTBE, more volatile hydrocarbons will have to be removed at the refinery to make RBOB. http://www.chevron.com/products/prod...ormance_issues Oxygenates are fuel additives (alcohols and ethers) that contain oxygen which can boost gasoline's octane quality, enhance combustion, and reduce exhaust emissions. The term oxygenated gasoline most commonly refers to the wintertime program that reduces emissions of carbon monoxide (CO) from motor vehicles. Although required by the federal Clean Air Act, winter oxygenated gasoline programs are implemented by the states. This section provides information about oxygenated gasoline, winter oxygenated gasoline areas, oxygenates (such as ethanol and MTBE), and health effects testing of oxygenates. http://www.epa.gov/otaq/oxygenate.htm Affects on fuel economy http://www.epa.gov/otaq/regs/fuels/ostp-3.pdf Oxygenated Gasolines and Fuel Economy http://www.chevron.com/products/prod...etin/oxy-fuel/ Oxygenated Gasoline Chemistry Oxygenated gasoline is a mixture of conventional hydrocarbon-based gasoline and one or more oxygenates. Oxygenates are combustible liquids made up of carbon, hydrogen, and oxygen. All the current oxygenates belong to one of two classes of organic molecules: alcohols and ethers.1 Footnotes 1 The word ether reminds many people of the anesthetic. Although the anesthetic commonly is called ether, its correct chemical name is diethyl ether (CH3CH2OCH2CH3). It is not used as a gasoline oxygenate because it is too volatile. In alcohols, a hydrocarbon group and a hydrogen atom are bonded to an oxygen atom: R-O-H, where "R" represents the hydrocarbon group. All alcohols contain the "OH" atom pair. In ethers, two hydrocarbon groups are bonded to an oxygen atom; the groups may be the same or different: R-O-R or R-O-R'. This is from Chevron themselves stating that they use alcohol as an oxygenate in the winter months which has less heat per unit and therefore more of it has to be used for the same power unit production. If you want to argue with the gas manufacturers and the government, go right ahead. Butane is a gas at our operating temperatures and therefore has no bearing seeing it will evaporate out of the fuel during production, transportation and filling our tanks. That is if it is even a constituent.
#26
F.Y.I. National winter/summer change in fuel is June 1st across the board. Also as of 2007 I believe the oil companies will stop using methanol in the fuel mixture due to emissions. a little info I came across earlier this week I thought you all might want to know
![]() 1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit 2003 malibu-bone stock(wife's car) |
#27
We should also make a distinction between reformulated gasoline (which we are not using here in Ohio) and the summer/winter blend. The diifference in summer /winter is the vpp and has nothing to do with oxegenated or reformulated gas, it has nothing to do with the additives, ethanol blend, methanol or that long additive word that shell uses. It is a vapor pressure issue , and quite frankly has nothing to do with using the gas in a vented or open tank.
As for your one question about the butane which is added to increase vapor pressure (add to summer gas for the winter) The butane really is a liquid under pressure (not only that) it is also a vapor above that liquid space and a vapor in an open container. If the temp is cold enough then we can simply carry it around in an open bucket just like water and is colorless and may even be odorless. The only way to get the vapor is to heat it abov the boiling point (like water) and the only way to get a pressure is to cap it up like plugging up a boiling pot of water on a stove. Adding Butane to gas does have a ratio of escape, it is very little. The butane stays mixed and increases vapor pressure of the fininshed product. It is not a fairy-tale per say, but the consumer does not have to know and cannot tell. As far as the fairy tale you have accused me of making out. I can say this that a performance difference between a full and empty tank of fuel would be far more noticeable by a driver than nearly any difference in gas blend from time to time or station to station or brand to brand. Just to be clear, we are not talking about octane, e-85,reformulated gas, ect. Only summer / winter blends, I really do not know any more about gasoline, I know a bit more about butane and far more about propane (both LP gas) |
#28
Winter gas is oxygenated gas and what they use to oxygenate the gas is alcohol, not butane, alcohol. Quote:
Read the links, see the information from the government and the fuel companies and you will see that the difference is alcohol, not butane, alcohol which has a lower amout of heat per unit volume and thus we use more of it to create the same unit of power. Quote:
#29
No, your links prove otherwise and say that although it used to be that way it is not any more, your links also reference 3 or 4 different reformulated gasolines and Ca as the state. I am responding to original post in s. Ohio. We may have just a few Chevron stations here.
On the "alcohol" please make a distinction as to which alcohol you are refereing to because it is true that "methanol" is added in non-ethanol blended fuels in the winter for fuel line freeze protection, but does not change the vpp of the gas as the quantity is very minute. Some have not had methanol for 10 years or so. It seems in addition to making a mountain out of a mole-hill as your own chevron links provide a 3% max difference in mpg test , they also agree with what I say when they say that the average driver will not see a differenence. If you'd like to get lost in the details, then specific time periods and specific stations need to be named as it can vary from station to station as to the alcohol content. Being specific in my NE Ohio area clecev and akron and canton and toledo and columus. Marothon bp, citgo (as of less than 1 year) are using 10% alcohol (ethanol) along with many others. Shel will soon use it also and lots of the generic stations do not use ethanol and may or may not use methanol. This info is time sensative and I think soon we will be on 20 % ethanol blend. On the Butane, some makers do it at the refinery to change the pressure of the gas and some "generic" places will push the butane right into the storage tank of "summer" gas |
#30
I'll be the first to admit that I'm not an expert on winter formulations, but I found an article that may help this discussion a little. I also want to compliment you guys for keeping the discussion civil.
http://zhome.com/ZCMnL/PICS/winterGas/winterGas.html THE TRUTH ABOUT WINTER GAS. BY JOHN HUNKINS As l write this, a suffocating blanket of snow clouds looms on the horizon while thousands of tanker trucks with winter gas roll inexorably toward gas stations in the Northeast and Midwest. In spite of the fact that I'm not a meteorologist, I know exactly what the clouds and cold weather will bring. Yet though I am an automotive journalist, I don't have the foggiest idea of what chemical grog fills those shiny stainless-steel tanks. It's surely got to be bad, no? And as winter's pall approaches New Jersey once again, the CSK office grumblings about winter gas resurface. While joining the ritual chorus of nay-sayers, I found myself thinking, What the hell do I really know about winter gas? Or for that matter, what do I know about fuel? Nothing. Funny how we're all experts on making horsepower, but nobody knows anything about fuel other than pour magic juice in, engine go boom-boom. Considering that horsepower comes from the fuel and not the high-dollar parts, wouldn't you say there's a pretty big gap in the information super highway? The realisation made me feel awkward, like a heart surgeon who doesn't know basic first aid. To satisfy my curiosity about fuel in general and winter gas in particular, I put in a call to Thomas Hart, a fuel chemist with a master's degree from Georgia State University. He's designed many spec fuels for racing, including Formula One, NASCAR, NHRA Pro Stock and motorcycles, and has previously owned his own race fuel company, Turbo Racing Gasoline. Thomas explained that gasoline is made up of many different chemicals, or components, not just one uniform molecule. Smaller, lighter components have a high volatility (they evaporate easily) and boil at a lower temperature, whereas heavier, more complex components don't evaporate as easily and boil at a higher temperature. Each fuel has its own unique signature, called a distillation curve; think of it as a recipe. The distillation curve tells the chemist which components are in the fuel and what their weights (e.g., their boiling points) and quantities are in relation to each other. A simplistic way of looking at the distillation curve would be to list all the fuel's components on a sheet of paper with the heaviest ones at the bottom and the lightest ones on the top. The trick is to have the right fuel for the right time of year. In the summer, when the temperature is high, the presence of too many light components will cause the fuel to evaporate too readily. This can result in vapour lock, an over-rich mixture and excessive evaporative emissions. In the winter, too many heavy components keep the fuel from evaporating, causing hard starting, a lean mixture, heavy hydrocarbon emissions and poor converter light-off. Obviously, since we can't change the weather, we have to use a fuel that will optimize performance and emissions for a particular climate. To do this, fuel manufacturers use heavier components in the summer and lighter components in the winter. This is a simplification of things, but it's close enough for government work. For reformulated winter gas, lighter, low-boiling-point components are added to the gasoline to increase volatility. This makes your car easier to start and accelerates converter light-off, thus lowering emissions. That's the official line on reformulated gas. And now for the teaser. According to Thomas, one of the most popular compounds gasoline refiners used to pump up the brew is called methyl tertiary butyl ether (MTBE). "'MTBE has several good things about it" says Thomas. "One, it boils in a range where the components have a fairly poor octane value. MTBE enhances the octane in the distillation curve. It fills in a good hole there around normal hexane and normal heptane. MTBE has an extremely high octane number, over 108. You've normally got some real junk [in the distillation curve]. [MTBE also] helps on acceleration and cold starting. On a carbureted car, it helps on fuel distribution." Gearhead translation: MTBE is a big check in the horsepower column. With a little fuel chemistry under my belt, I called Mitch Markusich, the proprietor and head brewmaster of PRO Racing Fuels in Mississauga, Ont., Canada. "The essential difference between summer fuels and winter fuels is the vapor pressure," says Mitch. "Manufacturers do this by pumping up the mixture with light-end components like butane, propane and isobutane." The caveat, according to Mark is that these components all have high octane values as well. Shoring up the positive aspects of additives like MTBE, which Thomas earlier asserted, Mark said, "Another major property in [reformulated winter gasoline] is the use of oxygen-bearing ether compounds like MTBE, ETBE (ethyl tertiary butyl ether) and ethanol. It's like pouring liquid oxygen into the combustion chamber. The engine doesn't have to draw the oxygen in because it's already available in the fuel." To illustrate his point, Mark pointed out that in Canada, where his racing fuels are made and used, the government doesn't allow the use of lead in racing fuels. Instead, PRO uses (among other components) MTBE to increase the oxygen content and octane of its fuels. Mark also pointed out that oxygen-bearing compounds like propylene oxide (a fuel additive outlawed in many racing organizations) and nitromethane have a considerable amount of oxygen in their makeup, over 5O percent in the case of nitromethane (By comparison, a 14-15 percent constitution of MTBE would give pump gas around a 2 8 percent oxygen content.) So what does all this mean? Obviously winter gas can't be compared to race fuel; the recipes are too dissimilar. Pump gas must adhere to ASTM specification D4814, which puts specific limits on the composition of highway fuel. But within these limits, there is some blending flexibility. And in many Northern states, there is also the requirement for reformulated fuels. Here's the poop: As specified by state law, reformulated winter gas contains any number of lighter, lower-boiling-point hydrocarbons (butane, propane, etc.) that just so happen to have an excellent octane value. Added to this may be any number of oxygen-bearing ether compounds (MTBE, ETBE, ethanol) that improve emissions and also have a relatively high octane blending value. So what's all the bad hype for? Price, for one thing "It's actually more expensive to make reformulated winter gas than normal, summer fuel, ' says Thomas Hart. Lower fuel economy is another concern. "The oxygen-bearing compounds displace fuel components, so it takes more fuel to get the job done. Normal gasoline has a stoichiometric ratio of 14.7:1, reformulated winter fuel runs between 14.3 and 14.4:1," says Mitch Markusich. And the complaints about poor performance? Mitch says, "When people bitch about the fuel, it's not really the fuel's fault. The weather is largely responsible; after all, it is winter. Low cranking voltage in the battery, increased oil viscosity, atmospheric condensation in underground fuel tanks and so forth." The bottom line is that when it's cold, winter gas seems to be the hot ticket for performance enthusiasts. Not only is the dense winter air good for horsepower, but the higher oxygen content and octane value of winter gas make the pot sweeter And as for fuel economy and price? When did that ever get in the way of having a good time behind the wheel? It s just too bad we have to deal with all that snow and ice". |
