| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: Question about injectors and turbos...
Wow, thanks alot Kevin, you rule!
![]() 2006 Wicked White Evo IX GSR 323 awhp / 311 tq. (Dynojet) http://www.projectevoix.com http://www.4WStuning.com 99 RS < 98 GSX < 06 EVO
#17
Hey kevin I understand the first calculation you did with the injector sizes/compensation but the second one about the leaning of the stoichometry you think you could elaborate on its the one with the 9.5/14 I didn't get where does that 14% come into play and is that a constant applied to any size injector?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
#18
I just want a simple anwser, 660's or low 700's, 255 pump, FPR, s-afc, evo3GT at around 14-20 PSI. Is that ok to run the car on? And not fuck anything up that I don't want it to? This is a budget racer, aka my personal roller coaster, and might not even see a track. Can the s-afc handle bigger injectors and the pump with the given range of injectors? Becuase I can't really afford dsmlink and TIT big injectors. I am so confused im going to stab my eye with a spork.
#19
650s or above + SAFC2 = too much timing advance. It's simply lying to the computer too much. Keep saving your money and get dsmlink, or run 550's and see how much psi you can run without going lean on a dyno.
Kevin's post earlier described the timing advance issue thoroughly, so I'm not going to try and explain that anymore. Do it once, do it right.
now - 2000 civic soon - 2002 is300
#20
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#21
Thank you thats what I needed to know
My only thought now is why would the ecu's target be 9.5 when 11 is a better mix?
#22
#23
Heres a question that I think is answerable but I don't know.. Especially don't know how to do the math so Ill just let kevin do it ( IF it is at all possible).
Ok so To my understanding with the rewired 190 and the 550's it can support 39lbs/min on the 16g (2g). Now the 16g max's around 42... Now lets say our line comes off and were running the turbo to the max. But we also have our safc set to -50%. HOW LEAN will You be running {assuming all other factors are negligible (boost leak and what not)}?
#24
Ok, on my budget and wants from my car right now, I would do a rewired 190, 550s, and the evo3. I would like to run approx. 18-20 psi on it, but is that doable on that setup?
Also, how much boost would you have to be running to hit those airflow numbers you were talking about, Kevin?
#25
hahah everything is the samething I just posted but just shorter, sorry kevin and crunchy =(
#26
I think you'll be fine running 20 psi on that set up. I already run 17 psi(no front mount). Been running it for almost a half yr now with my current set up. You have a front mount so that fuel/turbo set up will benefit(sp) much more. I'm pretty sure the rewired 190 be fine too, but a 255 be safer most likely(fpr is your call).
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels --the DD-->99 ACURA 3.2 TL --Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods |
#27
550s would be set at -18%, with another ~14% for getting to 11:1, so about -32%. I'm not sure why you'd be at 50%. That would be shooting for nearly 14:1, which is much leaner than you would end up with targeting a more normal AFR but maxing out the 550s, as mentioned above. Quote:
Another interesting thing to note is that by pulling the line off my wastegate actuator and installing my BOV backwards (or run my Gus Modded 1g BOV that I just installed) I get 42 lbs/min across every single gear from start to finish. Boost will hit anything from 25 to 28 psi at the beginning of each gear, but will taper to the same 19-20 psi value at redline. The turbo maxes out based on airflow. The boost is an afterthought. Boost is left over airflow The best way to keep it safe is to know the numbers, and log airflow. On a 2g any ODB2 logger reads airflow. My pocketlogger read in lbs/min. You can convert this to g/rev with a little work. Unfortunately you can not read airflow on a 1g logger, DSMlink is the only way. DSMlink provides airflow/rev, and airflow/time, in a variety of units.
#28
So then if you say that by your calculations the 550's at -50% can still put the a/f at 11, with the evo16g flowing at max then technically can't the 550's support that turbo?
I do realize it leaves no margin for error
#29
until you raise the boost past that calculation.
#30
But the 16g won't be able to raise boost because it is at full boost
