Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-29-2006, 01:46 AM
CAFB 04-12 CAFB 04-12 is offline
Re: 2003 Jeep GC overheating in idle
Originally Posted by hulkmn069
i just got done replacing the relay and it's easy. you don't have to take the whole front bumper off. it took me about 45min tops. and cost 35 for the relay. just pull the headlights out, un bolt the two fender bolts at the end of the bumper. undo all the torx bits around the grille and on top of the rad suppourt slide the bumper forward (you'll see one additional torx bolt on each side under the headlight bucket to loosen) and loosen the splash sheilds out of the fender. you don't need to break any of the snap rings or clips. once you get everything loose pull up on the whole thing and you'll see the relay. it's simple oh yea i have a 99 so it should be the same
Where did you buy your relay from? Are there any good websites to order from? What part number did you use?
Chad
Old 05-29-2006, 06:36 PM
hulkmn069's Avatar
hulkmn069 hulkmn069 is offline
Chad
i just got it from advance auto parts. there are i think three of them when the bring it up it's the one that's around 35.00. they should know wich one you're talking about if they are any good at that store
Old 06-12-2006, 10:30 AM
For those of you following this fix, I took some photos of the relay as I was fixing it. It sure was troublesome to reach: I had to take the front bumper facia off as well as the headlamp and inner grill in order to get to the relay. Why Chrysler put it here is beyond me. I paid $70 at AutoZone for the relay but it seems like others paid less elsewhere. The relay is a simple pull-and-replace type and screws into the frame of the front fender. After replacing the relay and putting the bumper and grill back together I tested the fan by letting the Jeep warm up to normal temp. The fan came on as expected with the temp needle at the 12 o'clock position and also came on when the AC was turned on. Definately a fix that is do-able by someone with average experience with tools and cars (me).
Here's a closeup of the position of the relay:
Wide angle:
Another angle:
Old 06-12-2006, 08:44 PM
bringselpup's Avatar
bringselpup bringselpup is offline
I can only guess they must be trying to get it away from the heat in the engine compartment.
Excellent photo's, they beat that diagram in Haynes by miles. I can see them helping future Jeepers for sure.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 05-02-2007, 11:16 PM
Iceyburnz Iceyburnz is offline
I hate to bump up old threads but I am having the exact same problem in my 2001 Jeep. The reason I bumped this thread is because everyone was talking about how great and detailed the pictures are and I need something of that quality so I can fix this problem.
Does anyone have the pics that were hosted on flickr that are currently not working? This will enable me to see the area and work on fixing the issue.
Thanks in advance for the assistance.
Old 06-16-2007, 03:08 PM
jonzi216's Avatar
jonzi216 jonzi216 is offline
I dont see any pics, reads that fotos are unavaiable, how can I be able to see them??!
Old 06-16-2007, 03:09 PM
jonzi216's Avatar
Cant see the fotos.......says fotos are unavaiable, how can I be able to see them?
Old 06-17-2007, 08:24 PM
Jepiza Jepiza is offline
nice....good information..thanks
Old 06-20-2007, 10:38 PM
hulkmn069's Avatar
the pics aren't here but pull the passenger headlight and loosen your front bumper the best you can and you'll find it. the relay is directly under the headlight it's dumb when you look at it but doable once you see it
