Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-10-2006, 09:06 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Turbonator---Worth the 130
Originally Posted by beyondloadedSE
Actually, Im going to disagree. The CD4E is a slushbox imho. The zetec mtx is almost as fast as the duratec atx. And btw, even with hectors sc on his zetec atx, it still ran 17s.
we all know the CD4E is junk, hectors car with a MTX it would be a good solid 15 second car.
Hectors car ran 16.1 btw
When he said slushbox zetec, I hadn't read it enough to figure that he was probably talking about a ATX zetec, not a zetec in general.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-10-2006, 11:32 PM
LukeContour LukeContour is offline
i found a site that sells the engine either the 2.5 l or the 3.0 liter for around 3 grand would that make sense to just replace the zetec?
Old 05-11-2006, 12:16 AM
pre98zetec's Avatar
might as well buy a new car then, you'd need a new tranny, ecu, subframe, exhaust assembly, way more work then anything, find a older 96-97 SE and put a 3.0L in it
-Josh-
Old 05-11-2006, 05:28 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
You can pick up a 3.0L for like $600.
But yeah, sk8ter is right. Youll have to replace the subframe, tranny, axles, wiring, etc, etc. Its just cheaper to buy a car already. If you want me to find you the list and the cost of everything that it entitles, i will. Its been posted on contour.org numerous times with people with the same question.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-12-2006, 12:05 AM
Yeah i really like my car it looks great... i really dont want a new car at this time so if you could find that list and link it or w/e that would be a great help thanks
im just one of those people that once i start something i finish it i dont give up
Old 05-12-2006, 09:26 AM
Used 2.5L or 3.0L Duratec Engine ~$600
All new wiring harnesses ~ $1400
MTX75 Transmission $1600?new $~700used
Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA
Clutch Slave cylinder $73.84
Flywheel $94.48
Left half shaft $150?
Right jack shaft $50?
Clutch Master Cylinder $29.19
Clutch Pedal Assembly $178.62 F7RZ-2455-AA
Clutch Hydraulic line upper $15
Clutch Hydraulic line lower $15
Clutch fluid supply line $5
Mount-fender side $85.22
Mount-tranny side-left $41.25
Mount-tranny side-right $40
Mount-cross member side-right $36.97
Shift Tower Assembly $72.97 XS8Z-7210-BB
Shift boot $29 regular $99 leather
Bolts- Clutch to flywheel $2
Friction Modifier $3.60 XL-3
Crossmember $450
Shift cables $45
3 quarts Mobil 1 synthetic ATF $15
Vehicle Speed Sensor-mtx $50
134Kohm resistor $1 Radio Shack
For a nice grand total of.....$5356.55 just from this list. Your still going to need a pcm thats out of a car with a 2.5L MTX. If you went with the used tranny and regular shift boot your still looking at about $4386.55. Of course, this assumes your doing all the work yourself too, you have all the tools required, and you dont need anymore misc parts that werent listed above.
"The CEG Nazi"
www.contour.org
Old 05-12-2006, 12:29 PM
Jason43's Avatar
Jason43 Jason43 is offline
I think if thats the route you want to take, it'd be better to buy a 2.5 car with a blown engine(should be dirt cheap, sub-$1000 area) and pic up a lightly used duratec 3.0($500-$600). You could transfer all the v6 parts over to the I4 car.
Just go to contour.org
1999 Ford Contour SVT
