Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-05-2006, 02:51 PM
getfreshco getfreshco is offline
Cool Re: my big Mouth!!! i got problems now
no i just figured it would be a lot more for a 350 (becasue there so damn powerful!...is it worth it?)
Old 05-05-2006, 03:22 PM
another question....... two bolt main or four bolt main....i have no idea what this means........ is it self explainatory?.......also roller or non roller cam? ....for a 350 or 305 information on both would be helpful!
Old 05-05-2006, 05:20 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Two bolt main caps are fine for your car. The difference is the middle 3 main bearing caps generally have two long bolts attaching them, one on either side of the crank. The 4-bolt engine adds a shorter bolt outboard of each long bolt. On either engine, the front and rear main caps attach with two bolts.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-05-2006, 09:04 PM
Blue Bowtie's Avatar
Registered Offender
What he said.
Two bolt main caps are usually not the limiting factor in an SBC street engine. 2-bolt blocks will typically handle 450 HP, whereas the rods (actually, rod bolts) more frequently let go at lower power levels and the associated RPM.
Your engine is currently equipped with a roller cam, and you should probably try to install a replacement that is the same design, mostly for longevity, and partly for the slightly lower internal friction.
A 350 may get about 1 MPG less in city driving, and should get identical mileage on the highway. If you tow or haul, the 350 will probably get a little better highway mileage.
