Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-07-2006, 12:26 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
Re: fuel pumps?
yeah I bought the wrong pump.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 05-07-2006, 12:27 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel pumps?
255 or 190? I might take it off your hands depending on what you want for it
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-07-2006, 12:28 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: fuel pumps?
Can you return it? Which did you buy fwd or awd? I have an awd pump sitting here so if you have a fwd we can compare the part numbers.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-07-2006, 12:29 PM
Re: fuel pumps?
yeah I bough tthe wrong pump
1997 Eclipse GS-T
Old 05-07-2006, 12:33 PM
Re: fuel pumps?
it is a awd 190 and I have a fwd
1997 Eclipse GS-T
Old 05-07-2006, 12:35 PM
Re: fuel pumps?
I dont have the pump yet its getting shipped to me right now
1997 Eclipse GS-T
Old 05-07-2006, 12:38 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: fuel pumps?
Wait, wait, wait. IIRC That fuel pump will fit just fine. its the connectons from the pump to the harnesses that are diffrent between models. There shouldn't be any diffrence between the 1g fwd & awd or 2g fwd or awd. Their would be a diffrence between 1g and 2g. Your fine.
Old 05-07-2006, 12:40 PM
Re: fuel pumps?
so the walbro 190 pump will bolt right in in place of the stock pump?
1997 Eclipse GS-T
Old 05-07-2006, 12:55 PM
Re: fuel pumps?
I just checked ExtreamPSI.com. The 1g have AWD, FWD specific fuel pumps. I don't know the answer to that. The 2g pumps on their website are not drivetrain specific like the 1g. Sorry dude, I've never had a 1g. Can you call the place tell them you think you bought the wrong pump?
Old 05-07-2006, 02:39 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: fuel pumps?
Originally Posted by scottsee
We'll, using the factory enrichment values over 2.1g/rev, assuming 43.5psi on the stock 2g FPR and a re-wire job done. You're looking at a max of 26.5 GPH of fuel flow on the 1g fuel pump, that caculates out to 26lb/min @ 15psi using thoes values as an example. the 2g fuel pump will push 34GPH and a max of 35lb/min at 15psi, same values.
Of course if you have an safc2 or other air/fuel controling device you can lean the massive 55% enrichment over 4500rpm's out to what ever you want. For example. If you tuned the 1g pump to 11:1 (same past values) you would net a max of 31lb/min airflow & 40lb/min airflow on the 2g pump.
Wait, i thought 2g's Ran at 33psi fuel pressure, stock... am i wrong? if so, let me know because i have my FPR set @ 33 psi... with a walbro 255hp pump, and a rewire...
Old 05-07-2006, 06:04 PM
Re: fuel pumps?
2g's run 43.5psi with the vacuum line disconnected. 1g's run a little lower at 37psi. I don't reamber what the fuel pressure is suppose to be with the vac lines connected, though 2HG = 1psi
Old 05-07-2006, 08:20 PM
Black99GST's Avatar
Re: fuel pumps?
well, i got the 33psi setting... if you find what its ment to be at, please, let me know...
Black99GST's Avatar
Re: fuel pumps?
well, i got the 33psi setting... if you find what its ment to be at, please, let me know... and yes, i have the vac line attached...
Old 05-07-2006, 11:09 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: fuel pumps?
scottsee is correct with his base pressure, and the comment about 2"hg being 1 psi. So simply do the math. If you have 14" at idle, and 43 psi base, presure with the hose on should be 36 psi. Etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-07-2006, 11:49 PM
Re: fuel pumps?
I just got done with a fuel pump re-wire. I makes a huge difference.
There is something wrong. even before the re-wire. when I hit the gas hard to like 5000 rpm and let off the gas the car wants to die. Well it does die but since I rolling the car starts back up like a push start. This started to happen when I put upper and lower intercooler pipes. any ideas? one more thing, when the car is at a dead stop at idle and i hit the gas and let off the engines still revs for about an additional second. is this normal? thanks
1997 Eclipse GS-T
