Old 04-26-2006, 02:16 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: New plugs, holy sh--
Just got one out underneath the passenger side, the little wires in the way no big deal. Should I be checking the gap of the new plugs before I put them in? (I'm using antiseize also)
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 04-26-2006, 02:25 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
absolutely check the gap. You can cause a shit load of poor running conditions from miss gapped plugs
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 04-26-2006, 02:35 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Unless you love changing them, which I highly doubt.
Old 04-26-2006, 02:58 PM
Dyno247365's Avatar
I figure they should be pre gapped for the engine, I just did 2 but oh man...I got antizeize on the insulator one of the plugs, tried to get it off w/o messing with the gap. Should I replace this plug or will it still work??
Old 04-26-2006, 03:08 PM
wrightz28's Avatar
yeah, you only need a dab of the stuff & that's it, not a wad of it.
Old 04-26-2006, 03:23 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
I would always check your gap. Its not hard and it could save you some hassle. Some plugs come pregapped but some dont.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 04-26-2006, 03:25 PM
Dyno247365's Avatar
They're Bosch platinums, no plus or anything
Old 04-26-2006, 03:26 PM
wrightz28's Avatar
even on platinums that "do not require gaping" you never know when some dip dropped em before they got in your hands.
Old 04-26-2006, 03:27 PM
Dyno247365's Avatar
is that a replace it answer or a no it'll be fine answer? I'm leaving for college, won't be back till 10 est. Leave all the helpful info you can, I just finished plugging the wire into the non-antiseized plug
wrightz28's Avatar
damn I was jsut saying that generally, I WOULD NOT USE those.
Old 04-26-2006, 03:30 PM
wrightz28's Avatar
in conjunction with the fact they are Bosch platinums I sould clean em up and bring em back for some good ol AC/Delcos is what I'm saying.
Old 04-26-2006, 03:31 PM
except for hte +4 ones that you just cant gap.
Old 04-26-2006, 03:35 PM
yeah. All I hear about those bosch plugs is that the platinum coating usually burns off and then they dont work very well at all. That and because it four nodes it spreads out the spark which can decrease power and cause misses under heavy load unless you compensate with a more powerfull coil which adds to the platinum coating burn off effect. A/c delco or NGK's are the way to go.
Old 04-26-2006, 03:36 PM
there were platinum 4's in my motor before I swapped them out with NGK's.
Old 04-26-2006, 03:37 PM
FormulaLT1's Avatar
Fight the powwa!!!
Sorry but bosch plugs suck. I tried a set on my LT1 once and the thing ran like complete crap. I thought my opti was messed up or something. I swapped in a set of non platinum A/C Delco's to see if it was the plugs and it ran like a champ again. I would not buy bosch plugs even again after that, I hear there O2's suck too. Also platinum plugs aren't all they are cracked up to be. They take a longer run time before they fire as hot as a regular plug will.
