Originally posted by xim-crow
it's my dream to build a car "full open" !!!
Does someone there already try to open a door for example ?!
Is that hard !?
Its not too hard, it requires the right tools and most importantly patience!!! My method is to first use a dental probe - very similar to the BMF panel scriber
http://www.bare-metal.com/panelscriberhowto.htm ... This deepens the channel a little for easier cutting but i dont use it to cut all the way as it will end widening the groove. Instead i work my way through with a No11 blade using the sharp edge to cut into the plastic then the back of the blade to shift it away.
Its a boring task and takes time, you really have to stop your self from trying to get the job done quicker by going faster or applying more pressure. I gaurantee if you do either, the blade will slip and may create a new unwanted panel line elsewhere on your model or end up embedded in your hand.
