| Latest | 0 Rplys |
#16 | |
![]() Join Date: Sep 2005
Re: P1404
Last time I looked at mine it was leaking a bit from the input seal, axle seals, and cover. I still havent check my breather to see if its clogged and causing it to pressurize. I will be checking it soon though when I change fluid again after being underwater.
One of my coworkers was nice enough to point out the fresh oil under the front of mine a couple weeks ago. Now I get to track down and fix a leak on the engine. I've never had a vehicle that leaked before.
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
#17 | |
Re: P1404
I cleaned my breather last fall because it was rusted up. I checked again and it was closed up again so I ordered a new one from St. Charles. It was less than $5. Definately worth it.
I think I found an EGR from a junkyard for $50. I'm about to order it. |
#18 | |
Re: P1404
Well, I was about to order an EGR from a junkyard today and the CEL went off, so that's good. Hopefully the thing stays off.
#19 | |
Registered Offender
![]() Join Date: Mar 2006
Re: P1404
If you know someone with a Tech II or Waekon EGR tester, you can have the valve checked rather than replace it on a hunch. You can command the EGR open and watch it to see if it moves of not. There is no other easy way to check pintle position feedback from the EGR valve to the PCM.
#20 | |
Re: P1404
The circuit board and wiper contact points internal to the EGR valve get dirty and/or burnt over time . IIRC, the post I saw on disemboweling the valve and repairing the 'paths' on the circuit board (with solder or solder pen) was on planetisuzu.
Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
#21 |
Isuzu Guy
![]() Join Date: Jan 2004
Re: P1404
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
#22 | |
Re: P1404
that procedure looks a bit out of my league. The CEL is still off, so hopefully it stays that way. If not, I'll order from a junk yard. I may try the procedure after I get a new one.
#23 | |
Re: P1404
stupid CEL, GRRRRR.
I'm ready to admit it will not fix itself. I'll order the new EGR tomorrow. Bowtie, I should go get it checked, but for the cost of the diagnostics, I can get a used EGR. I'm hoping this will take care of it. I keep looking at mazda 3's. I like them, just don't want to spend the money. |
#24 | |
Isuzu Guy
Re: P1404
Yup the 3's are nice. My wife drives one. 30-35 MPG, so it is our road trip (or any trip we are both in the car) car.
#25 | |
Re: P1404
Those are really nice looking cars. I think the ford fusion looks cool too. I do miss the ~11gal fillups of my 2001 nissan sentra.
Just not enough room for us. The only thing I hated about the small cars we owned was the feeling of sitting on the ground. Never liked falling into them and then hauling your arse out. $3/gal+ we'll have to learn to like it!Joel
#26 | |
![]() Join Date: Apr 2004
Re: P1404
I'm starting to see more and more of those M3, as well as the M6's - I like both of them.
What's the set-up of the engine? And is it an easy one for maintenance, or does it require a lot of maintenance between 40-100k miles??
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
#27 | |
Isuzu Guy
Re: P1404
Well the good thing is that it doesn't have a timing belt, but has a timing chain.
The one goofy thing is the fuel filter is in the tank! There is no recomened interval for changing it. As for the setup, it has a 160 hp and torque .... not sure. We have 5 speed so it is pretty zippy. Our previous car was a 1992 Prelude Si (non-vortec, 93 was the first year of the vortex), and I think it had a bit more get up and go to her (also rated at 160hp).
#28 | ||
Re: P1404
Joel
#29 | |
Re: P1404
I heard the 3 has an odd type of oil filter. It is not the simple screw on type.
I am going to inquire about a lease, probably not going to do it, I still like the Rodeo, but I'll be honest, gas is a factor now. The CEL has gone back off. I'm still going to check out the J/Y. |
#30 | |
Re: P1404
Yes, a bunch of vehicles use a drop in oil filter now. It's basically a plastic cannister with a threaded lid. Un-screw the cap, pull out the old & drop in a new oil filter element. Sealed trannys, drop in oil filters, maint free everything..
Joel
