| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
#16
Re: Sub wiring
SELLING THE HONDA... |
#17
Re: Sub wiring
Power antenna is on as long as the hu is on. I always use the power antenna for a remote wire when i use more than 2 amps. But on some HU its a possibility.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
#18
Re: Sub wiring
i ran a wire from the hu to the remote on my amp the wire in the back of my hu has a fuse is that the remote wire or the power atenna? i am realy thankful for the help.
#19
Re: Sub wiring
#20
Re: Sub wiring
i think i need to get car sterios for dummies lol what do you mean by steady hot
#21
Re: Sub wiring
This particular wire lead, with the inline fuse, should be connected to a 12vdc pwr source that will not de-energize when the car is turned off.
The term steady hot refers to the fact that it is always energized, It is used to power your clock, keep system memory, etc when the car is off.
#22
Re: Sub wiring
Navy thanks for the info i just have to see which wire is the remote i know thats its the blue one
#23
Re: Sub wiring
in car stereo lingo ... it is usually referred to as "constant 12V"
#24
Re: Sub wiring
I've heard it that way and hot wire but never steady hot.
#25
Re: Sub wiring
i have a sony hu with a amp in it 52x4 and a 300 watt in the back is a 10g wire kit good enough
#26
Re: Sub wiring
I wouldn't go smaller than 4ga.
SELLING THE HONDA... Last edited by NAVY IC; 05-14-2006 at 11:05 AM. |
#27
Re: Sub wiring
With a 300 watt amp the smallest that you could go would be 8 gauge wire for power and ground. It would work with 10 gauge but if it ever shorts out somehow then you're looking at the insulation on the wire melting off and possibly causing a fire.
#28
Re: Sub wiring
A 2 ohm stable 2 channel amp is 4 ohm stable bridged and a 4 ohm 2 channel stable amp is 8 ohm stable bridged. |
