| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#16
Re: My friend Mike's Talon setup plans.... opinions please!
My certified low 11 second laptop was 50 bucks
You might be surprised by howlittle computing power is required to run DSMlink, it doesn't take much at all. Mine is a 475 mhz with 64 mb ram and windows 98. Had to bondo the cracked lid. I would not hesitate to run a stock gasket on anything up to 30 psi, even on a stroker. Metal HGs might stand up a little better to high knock, but I would rather have a HG go than something else
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#17
are you talking about a completely stock longblock with stock headgasket and stock head bolts??? I have always heard not to run that high, I've had two local buddies both blow their gaskets because they were running around 25psi on everything, but little knock, and plenty of fuel.
now - 2000 civic soon - 2002 is300
#18
For a 6 bolt, stock bolts aren't too bad, but ARPs should be a no brainer anyway at ~75 bucks. For 7 bolts with stretchy bolts, ARPs are mandatory regardless of boost IMO. Though the EVOs tend to do well with them to ~28 psi on the stock turbo dropping to 21 by redline, running 11s and making something over 400 whp. I lost my HG however, two of the stock stretchy bolts were loose when I got the valve cover off. Poeple have run over 30 psi and made over 600 whp on stock composite gasket with ARPs. They are also almost impossible to fuck up for newbies, while metal HGs require some special considerations to install properly (properly = will last longer than a stock composite gasket). In my opinion people should stick to the stock type gasket for as long as possible... It can also act like a fuse and keep you from breaking pistons. HGs are much easier to change
#19
so, with nearly 100k on a stock 7 bolt longblock, is it time to upgrade to ARP bolts? Is it even worth it considering with a headgasket that can't have too much left? 18 psi daily, 21 or so on some nights, I am debating on whether or not to get the ARP bolts now,and keep this stock headgasket as long as possible, or to just replace it with a cometic now(all proper preparations would be made, mirror finish, etc...) With ARP's, and a good tune, and a 10 year old stock headgasket with 100k, 25psi for track and dyno would be fine?
#20
You can run it as long is it still works, but I have a severe distrust for stretchy bolts. They give the stock HG a bad name. If you don't mind doing the work, it's good preventative maintainence. Since you have to pay for a HG, you can wait until this one fails and do it then, or pay up and do the HG and studs now. Either the cost and the work will be the same. If you are set on a cometic and need to resurface the block, I would wait until you do a full rebuild/build, not worth pulling the motor, disassembling, resurfacing, reassembling, and risking CW. IMO.
#21
Stretchy head bolts? Thats the damnedest thing I have ever heard in my life. Some certain Mitsu engineers must have had the good shit that day
#22
most head bolts are "streachy". What that is, is a torque to yeild bolt
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
#23
, I thought that they were actually strechy, like rubber or something. Or had a rubber section in them.
#24
Haha not quite
#25
It does sound strange, but it's the way its meant to be. On my site there is a page about ARP headstud info, I explain why the bolts are meant to stretch in there, if anyone is interested.
#26
If you have any other fuel controller, using the translator settings would be stupid and make tuning much more difficult. Quote:
I dont think I'll ever max out the injectors and will probably never upgrade from DSMLink. (Except when they come out with version 3. It will be close to a stand alone anyways)If you want to make 350hp on a 16g, you wont get there on an AFC. You dont have the timing map or cams to get you there. You will need cams and DSMLink for sure. I made 275whp @ 15psi on the EvoIII16g just because I was over running my stock fuel pump. I also had a lot more modifications than he does. I hope he is prepared to be upset. My suggestion is do it once and do it right. Even if he has to save up a little more and wait a little longer to get DSMLink, it will save him money. |
#27
I'm not sure what you are trying to say about the MAFt/AFC combo. MAFt and SAFC both alter the airflow signal in the same exact way, so both will have the same exact effect at the ECU. Doesn't matter if you do the correction/tuning in the MAFt or the AFC. You will get more range of adjustment, perhaps that is what you are refering to. Idle and timing will be equally affected though.
#28
What I am trying to get at is with the Translator/AFC combo you can run any size injector you want. You arent restricted to 680/720s with just the AFC. What you have to do is set your injector size in the Translator box. Say you want to run 950cc injectors. You set the BASE knob at 7 and the AUX knob at 7. With that set in the translator, you can have your settings in the AFC set at 0. The only reason I know this is I got curious one day and tried it. I was wondering why they put all setting for the injector sizes up to 1000cc I think, maybe a little bigger I forget. My injectors were 950s (thats why I know the settings ) so I set everything in the AFC to 0, put the BASE knob to 7 and the AUX knob to 7, left LOW-MID-HIGH knobs at 0. Turned the car over and it fired right up. It idled perfectly. It was running a little rich but nothing that couldnt be fixed with the fine tuning of the AFC.
#29
-Brian
#30
Because it doesn't work so well
You can run injectors that require more than 50% adjustment, but you are still going to have all of the other problems you would with just the AFC. Airflow signal is way too low, timing is too high, idle is less than ideal, etc. The AFC and MAFt work in exactly the same way. You could achieve the same thing (being able to run huge injectors) by running two AFCs ![]() To give a quick example, lets look at 950s. Correction factor alone is -53%, so the AFC certainly is inadequate. With a MAFt and AFC, it's easily compensated for. However, the airflow signal is still going to be at LEAST 53% lower than it actually is. Airflow will need to be over 75 lbs/min at 7500 rpm to still be over 2.1 gram/rev at the ECU I think it's safe to say timing would end up in the upper 20s with a more normal airflow of say 40-50 lbs/min. So yes, you can compensate for lager injectors with the MAFt/AFC combo, but no, it's still no where near the same as DSMlink. Just a fancier AFC.
