Old 04-17-2006, 07:32 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Re: Fuel Pump
Originally Posted by BlazerLT
I would still replace the ignition switch.
Remember guys, it is a 1997 and several people have found the switch to become defective and not send the prime signal to the pump.
You guys know more than me about that. I never had to deal with a 97. I can only guess based on the problems I had with my 2000.
So if this is a prime suspect I would have to back you guys up
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 04-17-2006, 07:26 PM
tatum3217 tatum3217 is offline
Smile Re: Fuel Pump
is there a way to tell which one it is? i need to get it fixed asap but want to address the reason it won't run first then tackle the secondary problem in the next couple of weeks. i would take it somewhere and have it looked at but I don't want to incur another expensive towing bill. thanks everyone for your help - i really appreciate it!
Old 04-17-2006, 07:54 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Fuel Pump
Your 1997 Blazer has a fuel pump test wire on it, it is the red wire near the Master cylinder. Send 12 volts from the battery to the wire and listen for the pump to wine. if it wine's, the pump is fine. Then you have all the classic signs of a bad ignition switch, very common on the 97's.
Keep us posted on your findings please..........
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
