Old 04-03-2006, 09:13 AM
littlewillie littlewillie is offline
Re: 91 1500 AC/Heater Floor To Face Problem
I was able to look at mine. Had to remove my ashtray to get to the area. My spring & clips had come off (see pictures) the control arms that controls the floor to face mode. What is not clear in the arm pictures is that the clips are installed in between 2 separate rectangle arm pieces. All the spring does is keep tension on the clips so they do not fall out. The problem I have now is, I only have one clip. I could not find the other one anywhere. I shook all the wires in the area. I blew the area out with compressed air. That one clip is nowhere to be found. I can only speculate as to where that other clip is. I was able to change the arm manually to select the face mode (for the A/C) & it stays there. I will try to locate another clip & get this fixed. It can be bubba fixed easily if I can't find another clip. 2000CAYukon could not find the part # on Delco's site. If anyone locates the # or knows where I can buy one, please post it here. I'll update this thread after I locate the part & get it fixed. Again I'd like to say thank you to 2000CAYukon. Those pictures are worth a 1000 words. You are the man on this fix.
Willie
Old 04-03-2006, 01:29 PM
2000CAYukon 2000CAYukon is offline
Willie
Willie,
You might get lucky at a dealer or you could probably find the part in a junkyard.
Glad the pictures helped you out.
//2000CAYukon
