| Latest | 0 Rplys |
| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
| View Poll Results: Which Turbo do you think would be the best bang for the buck? | |||
| AGP RS49T (internally Gated) |
1 | 6.67% |
| Big 16g (Internally Gated) |
1 | 6.67% |
| 20g (Internally Gated |
0 | 0% |
| AGP RS49T (38mm externally Gated) |
3 | 20.00% |
| Big 16g (38mm externally Gated) |
2 | 13.33% |
| 20g (38mm externally Gated) |
8 | 53.33% |
| Voters: 15. You may not vote on this poll | |||
Show Printable Version | Email this Page |
#16 | |
Re: turbo Decision
why you lean twords the internal gate? isnt external better? I think i'm going to go with the 50 trim, and DNP's 16G External Dump manifold/o2 combo, and tial 38mm Waste gate. sound good? this should cover my power goals, and also, give me a little room for error... (hopefully none, but I am only human) Please people, i have to get $2K @ $7.50 an hour, starting from $400, so keep voiting and taking here, I really REALLY would like the get the best setup i can. Also, keven, what do you think about this specific set up? I will be running DSMlink, with FIC 950cc's and 93 oct. gas...
#17 | |
Re: turbo Decision
You want to be externally gated. It will make your life much easier.
Got AWD? Some people buy super cars, other build them ![]() ----Click It, For Mods and Pics---- '95 Mitsubishi Eclipse GSX - For Sale '05 Volkwagen Golf GLS TDI - My daily driver '03 Ford Excursion 6.0L PSD 4x4 '13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost '08 Buell 1125R '83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap |
#18 | |
Re: turbo Decision
yeah thats what i always thoght too, also does it matter where to mount the waste gate? Manifold or o2? i heard its more like, personal preference...I'm thinking on going with the manifold Dump... any input on this?
#19 | |
Jizzed In My Pants
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Re: turbo Decision
Search for it under Kevin's name, I remember him going over this. I dont exactly remember why, but he said go manifold dump.
#20 | |
Re: turbo Decision
yeha, thats what i wanted to do... lol
#21 | |
Re: turbo Decision
It's best to attach the WG to close to the flange where all of the runners come together. If you cant do that a lot of people gate the #1 runner.
#22 | |
AF - Advisor
Re: turbo Decision
Yes, I prefer the manifold dump. The o2 dump setups work, but the exhaust has to still take the torturous stock path to the gate raising the minimum boost you can run. It may still be below what you need to run, but on large turbos it can be a problem. Even on GT35R sized turbos my 38mm gate venting the colector could hold 13 psi (spring pressure) to redline. Might have even worked for the T67, but I went to a 20 psi spring. The angle at which you attach the WG is also important. My SFP manifold runs the WG off the front of the collector, so all four runners give the exhaust a straight shot from the head port to the WG valve.
The only real advantage I see to the O2 mounted setups is ease of returning the WG exhaust to into the main exhaust. Noise concerns are perfectly valid, and if this is an issue O2 mounted is the way to go.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
