Old 03-24-2006, 08:11 PM
777stickman 777stickman is offline
Re: how to get headlights to turn off
As for the DRL relay running the low beams, thas bullshit as I pulled mine 2 months after I got the truck and my headlights have never failed me.
Well, BS? That must be true because you said so!!! However on '99 old body style and older with DRL's I challenge you to take the relay out and see if the low beams come on. When they don't I hope you have room to stuff your remark WTSDS.............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-26-2006, 12:12 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
I agree with Stickman.. the older body styles use the low beam as the DRL. The 99 and up (new body style) have a separate lamp for that.. I know.. because I have a 2000 Silverado.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 03-26-2006, 03:29 PM
chuck16's Avatar
chuck16 chuck16 is offline
I was thinking of using Diodes to make the DRL's come on with the Headlights. So that when the headlights are on the DRL's are on as well. I know there is a really complicated procedure on here somewhere but there should be a simple one somewhere too.????
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 03-27-2006, 07:52 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
As you may have noticed, this is the NBS Silverado forum. My comment is completely true for the 99+ nbs. I am assuming he's talking about a NBS, b/c he said the HEADlights come on automatically and won't go off which is typical for a 99 nbs Silverado. I won't comment on something I have no idea about, which would be the DRL's on a CK 1500.
I sir, challenge you to pull the DRL relay out of the vehicle he's talking about. When the low beams do work, you may use them to see your way around WTSDS.
This was about headlights anyhow, not DRLs.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-27-2006, 05:26 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
i have a 2001 but hitting the override button rapidly doesnt turn off any of my lights??
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 03-28-2006, 01:36 PM
Is that a question or a statement?
pushing the override button 3 times will override the automatic headlights.. at least until you take the key out. then it defaults to automatic again.
Old 03-28-2006, 02:31 PM
Sorry it was a question... ive tried many times to turn off my automatic headlights by pressing the override button 3 times but they always stay on. Any ideas on what could be wrong?
Old 03-29-2006, 07:56 AM
When you push the override button, does your dome light turn off and stay off when you open the door? if it does not, then you may have a switch problem
Old 03-29-2006, 01:23 PM
The dome light turns off and stays off when i push override. Any other ideas?
Old 03-29-2006, 07:37 PM
Not sure.. It could be a relay that is out. check all your fuses.
Old 03-29-2006, 10:24 PM
It's not that big of a deal for now. I'll check the fuses and everything else when I'm bored and have nothing to do.
Old 03-31-2006, 02:20 PM
chevy00 chevy00 is offline
i believe if the truck was made in canada this will not work. my 00 silv LT was made in canada and registered there and this option does not work. do a search in this forum and see. i think i read it in here somewhere
