Go Back   Automotive Forums .com Car Chat > Cars in General
Old 05-30-2003, 11:43 AM   #16
ChaosStarter
Send a message via AIM to ChaosStarter
I was leaving work a few weeks back and had to pick up some of my tools from the install bay (work at best buy). as i'm leaving, one of my buds there says i should do a little burnout because he knows how easy it is for me to spin the tires b/c of the tq.
anyway, throw on the e-brake, put in down into first, and just let it rip. sat there for about 10 seconds just squeeling away, let off the brake, and took off both tires still smoking. the smoke was all around the parking lot, and i left two tracks about 50-60ft long.
my friend told me, "awesome burnout" and gave me $2 for the tread i just killed. lol. :sun:
1999 Pontiac Grand Prix GTP (2dr)
"Gold" Package
~drop in K&N
~3.4" pulley
~drilled 180º T-Stat
~Casper's cooling fan switch
~U-bend/Resonator removed
Best 1/4: 13.58 @ 100.17 10/25/03
Best 60': 2.07 (stock RS-A's at 30psi)
Best Dyno: 5/3/03
197.4fwhp/262.4fwtq
Coming Soon....
turbo!!
ChaosStarter is offline   Reply With Quote
Old 05-30-2003, 08:37 PM   #17
Jimster
Here for the pussy, man.
Jimster's Avatar
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
I don't do burnouts- I see little point in them
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Jimster is offline   Reply With Quote
Old 05-31-2003, 04:26 AM   #18
1BAD305
i usually do a brake stand in 1st at like 5k, let off the brake give her about 5 ft in first hit 2nd and let her rip for a while, around 180 ft we measured.
a few places my friends and i lay down the rubber:
89 ROC - 305 TPI 5 SPD - 13.9 @ 97.08
1BAD305 is offline   Reply With Quote
Old 11-23-2003, 09:15 PM   #19
urza220
Well, from the few cars I've driven, I've never gotten a really good burnout, but the worst one was pretty funny. It was the day of the prom and the limo was really late, so my g/f and I decided to take off in her Neon. We were on the highway and there was a lot of traffic, so I was really pissed, so when the light goes green I put it in gear at about 4000 rpm. The car lurches forward with this huge screech for like a splitsecond, then it resumes normal sluggish acceleration. That was the weakest burnout I've ever seen, but the car smelled like burnt rubber for like 15 minutes.
urza220 is offline   Reply With Quote
Old 11-24-2003, 05:57 PM   #20
Ground Rat
Ground Rat's Avatar
Send a message via AIM to Ground Rat
Re: Whats the best burnout you did with your car
It was probably the clutch, LOL! The best burnout I did was when I first bought my truck (454SS). It makes really good torque from the factory and since it's a truck, it doesn't weigh much in the rear. It does come with an LSD, so both tires get to participate in making smoke. Anyway, a friend and I drove for about 15 minutes until I found the perfect spot. It was in an empty parking lot behind some building where a cop wouldn't be able to see us. I started off doing donuts until there was so much smoke it was hard to see. Then I power-braked it around the rest of the parking lot making sure I left my mark everywhere. I spent the rest of the month wasting my tires in virgin parking lots and had to get new tires at the end of the month.
'87 Turbo Sprint
'90 Turbo Voyager
'92 Typhoon #591
Ground Rat is offline   Reply With Quote
Old 01-22-2004, 05:26 PM   #21
Hypsi87
I got your v-8 swingin!!!
Hypsi87's Avatar
Send a message via AIM to Hypsi87
This was not the best one but it's pretty good. Not bad for one wheel wonder
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Hypsi87 is offline   Reply With Quote
Old 01-24-2004, 07:46 AM   #22
DGB454
Send a message via AIM to DGB454 Send a message via Yahoo to DGB454
It's hard to say. I try not to do too many burnouts because it desrtoys the tires. I can generally do a burnout as long as I want from a dead stop(not using the brake method) and for quite a ways when I shift into second and I can break the tires loose and keep them spinning for a ways shifting into third (but spinning the tires when traveling at higher speeds wouldn't really be considered a burnout woud it?)
DGB454 is offline   Reply With Quote
Old 01-28-2004, 03:43 AM   #23
youngvr4
STREET RACING GURU
youngvr4's Avatar
my dads C5 vette down in arkansas this road had just got finished being rebuilt 5 days prior, i'm at a stop sign and do a burn out for about 7 seconds let off and i wasn't going anywhere so i let off and punched it again and fish tailed around the corner(i love doing that) anyhow when i came back the same way i came i seen that i digged into the ground with my tires it melted the ground. thats my fav and best
youngvr4 is offline   Reply With Quote
Old 01-31-2004, 11:10 AM   #24
MagicRat
Nothing scares me anymore
MagicRat's Avatar
There seems to be a common theme here, the best burnouts are done in your moms / dads/ friends / borrowed car.
Can't you guys do burnouts in rental cars like me?
I have two memorable burnouts. One was in an old full size Chevy van I bought for $300 as a farm truck. the tires were old and hard and I spun some massive donuts, lighting up the left rear all the way. I had to stop because the inside of the truck completely filled up with smoke (through the rust holes) so much I was choking and couldn't see.
Another was in my big block Fleetwood. It spun the tires so fast, and again they were old slippery rubber. Anyways, after about 30 sec. there was a pillar of smoke about 30 ft high, as there was no wind that day.
MagicRat is offline   Reply With Quote
Old 02-14-2004, 10:22 PM   #25
alphalanos
It was raining on some really smooth asphalt and i did a burnout into 4th gear in my A/T Lanos. it was cool
alphalanos is offline   Reply With Quote
Old 02-16-2004, 12:18 AM   #26
KustmAce
Grande Boleros de Fuego
KustmAce's Avatar
i have a cavalier that i white smoked once. My clutch is pretty messed up cuz i used to peel out way too much so i dont anymore
MAKE ART, NOT WAR
KustmAce is offline   Reply With Quote
Old 02-17-2004, 12:07 PM   #27
ragnarok
I did a AWD burnout in my 02 WRX at the track in the water box while the guy i was about to race, in an acura integra, watched with his jaw dropped. 240hp to the ground will do that.
ragnarok is offline   Reply With Quote
Old 02-19-2004, 09:18 PM   #28
NCCaddy
my cadillac Deville, being front wheel drive, looks pretty sick in burnouts. I did the usual right foot on accelerator and left foot on brake and that huge V8 took off like a mo.
NCCaddy is offline   Reply With Quote
Old 03-05-2004, 09:44 PM   #29
CamaroSSBoy346
CamaroSSBoy346's Avatar
Send a message via AIM to CamaroSSBoy346
does a 10 ft burn out in grass count? My garage is off of my house, i just got done workin on my car and was gonna park it in the driveway, so i did a peel out on the grass infront of the driveway and seperate garage. Once i get my Bird legal, im gonna burn those BGF's to the metal
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
CamaroSSBoy346 is offline   Reply With Quote
Old 03-11-2004, 12:48 PM   #30
jdrumstik
jdrumstik's Avatar
I was in sandiego in our kia minivan, real steep hill, let off the brake and the car is rolling so I gave it gas and more gas and more gas, the stupid torque converters never kick in on those cars, well eventaully it did.
then the other day, I was tempted to take the 88 prelude for a joy ride (im only 15) I decided just to repartk it, im in frist gear, hit the gas, screeeach, all the way through a nasty u turn, the thing has 4 wheel steering. pretty narly.
and then in our chevy van, its got a 4.11 rear end a 454, pop it into reverse and watch them slide in the sweet twoing mirrors.
jdrumstik is offline   Reply With Quote
