Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-05-2006, 10:19 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: Buying FPR, which is better?
So then the REWIRE of the fuel pump should take care of that? Sorry for so many newbie questions, It's almost spring so I am getting excited to start working on the car instead of just maintaining it.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-05-2006, 10:26 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
1gs have a different stock setting. I think it is 37 base. I did some searching and couldn't find it quickly.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 03-05-2006, 10:28 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I can find out for sure tomorrow if I remember
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-05-2006, 10:45 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Fuel system pressure at idle taken from the Haynes Manual for 1g's:
Manual: 36-38psi with vac hose detached, 26-28psi with vac hose attached
Auto: 41-46psi with vac hose detached, 32-34psi with vac hose attached
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-05-2006, 10:48 PM
MexRocket's Avatar
Thanks Th0r and everyone else, what about the re-wire, that most likley will take care of the fuel cut right? Th0r did you already get your car>
Old 03-06-2006, 09:23 PM
MexRocket's Avatar
First off, rewiring your fuel pump causes the pump to flow MORE. You are overrunning your factory FPR currently, why would flowing MORE help? If you get a adjustable FPR then you can rewire the fuel pump, but you dont need to rewire it with the 255lph on your current setup. Even in factory wiring form the 255lph will handle well over 50lb/min of airflow. The 14b at most flows around 29-30lb/min of airflow.
Get the Megan FPR if you want, but personally I would get something that is definately proven when it comes to fueling. Megan Racing is likely good for exhausts, but without something allowing me to monitor the operation of the FPR while boosting I wouldnt want to use anything but an Aeromotive or an SX regulator
That is what a guy said on talk.. He doesn't think I need the re-wire..
