Old 03-06-2006, 08:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Smile Re: 97 blazer starts then stops, new fuel pump, new problem
Originally Posted by old_master
Thank you for your efforts! I stand corrected on the redundant circuitry. Seems like a rather foolish move on GM's part to one: program the ECM to override the OPSU and two: leave the wiring and switch in place raising the cost of the vehicle. Oh well, I suppose they've done other foolish things too.
Thanks, OM
10-4 on that GM ideas old_master.
GM ideas are hard to figure out sometimes. On the newer 00 up models they are doing away with the oil pressure switch for fuel pump.
Also A lot of even older cars are leaving the nut off of the front of the air condition compresser to save a nickle.
Mt
MT
Old 03-06-2006, 09:02 AM
MT-2500's Avatar
AF - Advisor
Originally Posted by blazee
I don't think so. It would have to be something that's internal to the ECM and not shown on the schematics. It would also have to be something that changed at some point because I know some guys have pulled theirs and the engine didn't die.
Blazee
Thanks for the after dark testing and letting us know what you found.
It does make you wonder about that oil pressure switch.
If it was working right it should has keep power going to the fuel pump.
MT
MT
Old 03-06-2006, 12:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Wy aren't we considering the ignition switch?
It is a common occurence on a 1997 and would cause this problem.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-06-2006, 01:28 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
From the original post, it appears that replacing the fuel pump solved the problem - for 18 months - and not this time...
Maybe the original poster is not clear in stating what solves the problem, what caused him to replace the fp the first time, or if the pump solved this problem the first time. funkamongus20 please clarify.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-06-2006, 02:32 PM
blazee's Avatar
blazee blazee is offline
Problem?
Nobody's ruling anything out. We were merely discussing the operation of the fuel pump circuitry. There are several things that it could be, including the ignition switch or even a malfunctioning security system. Like Brian said, we really need more info.
Old 03-06-2006, 02:46 PM
BlazerLT's Avatar
AF -Advisor
Yea, you are right, too bad the guy posted his question and left.
Until he returns I guess there is no point in really going in either direction.
Old 03-06-2006, 02:54 PM
Brian R.'s Avatar
Resident Chemist
The guy is probably too busy at his local part store buying another fuel pump, a oil pressure sender, a fuel pump relay, an ECM, a wiring harness, and an ignition switch.
And now he comes back and goes out for a new security system.
Old 03-06-2006, 03:01 PM
BlazerLT's Avatar
AF -Advisor
lol, maybe he is at the bank securing a loan?
Old 03-06-2006, 03:13 PM
old_master's Avatar
Advisor/Moderator
It was a pretty in-depth discussion! Maybe we baffled him and he's out buying a new vehicle! Might be a less expensive alternative when you figure in all those parts. I learned something from this thanks to MT-2500 and Blazee. Learned GM makes some crazy choices. Just when you think you have the answer, they change the question.
Old 03-06-2006, 03:32 PM
Brian R.'s Avatar
Resident Chemist
When you look up "crazy choices" in the dictionary, you see a Ford emblem....
Old 03-06-2006, 03:41 PM
blazee's Avatar
Problem?
It's a good thing that I didn't mention a plugged cat or a bad ECT sending unit.
EDIT: Oops
Old 03-06-2006, 09:46 PM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
I took the liberty of testing to see if mine would stay running when I pulled my fuel pump relay, and it did say running. Just a FYI.
1996 Blazer LT 4 Door, 4x4, 4.3L Vin W.
