First you have to take out the airbox. On the inside there is a golden ring w/ 4 screw holes that u have to pop out. Try not to bend the base too much. This piece gets bolted back onto the end where the box was just removed. U can use silicone around the edges to keep it air tight. This is where you will have to use your imagination. I was able to use an airduct tubing from a friends leaf blower. It already had a plastic piece at the end that was 4" and went to 3". the cone filter fir perfectly on the 3" side and is secured by a circular metal clip. The tubing was bendable and fit nicely over the gold ring. This side was also secured my a circular metal clamp. then just drilled a hole in the plastic piece and secured it w/ silicone. Vuala, I working popcharger. Since the tubing and filter was supplied free of charge, the actual mod cost me under $5. the tubing that will work can be difficult to find though. I got lucky because my friend was able to supply everything and do it for me.
