Old 03-16-2006, 03:07 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Timing belt skip?
most likely lifter tick.
but if you want to double check, then you have teh process. simply turn teh crankshaft.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-16-2006, 09:26 AM
sLADe781 sLADe781 is offline
Originally Posted by Stealthee
Plenty of people have driven on one or two teeth being off. Some even as much as 3. There is no need to rotate the engine when all you have to do is count down the teeth like I mentioned.
And the original post says the cr crackles in the morning. If the timign was off it would make the same sound all the time. It is most likely lifter tick.
Thanks for the replies Stealthee and Linebckr. I'll have to check again when it stops raining. Just a little confused though so umm...isn't the lifter tick supposed to "tick" as opposed to crackle?
Old 04-19-2006, 02:05 PM
Sorry to bring this thread back up but no body ever answered my question...lifter tick is supposed to tick, not crackle right? And it's supposed to keep ticking on and on right? Because my car only crackles in the morning and that's it.
I was also wondering...how can you tell if your valves are bent? That's usually what happens if your timing belt fails, right? I mean, if it snaps or one of the pulleys mess up or something...
