Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-08-2006, 12:04 AM   #16
bringselpup
bringselpup's Avatar
Re: Changing Spark Plugs
RC12ECC cross to Autolite 985 according to www.sparkplugs.com
I have 985's in mine. Hey at least a six pack of them won't bust your wallet to see if they work better.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
bringselpup is offline   Reply With Quote
Old 03-08-2006, 07:56 AM   #17
BenBB
If teh jeep is still shuttering, double check that you have all the coils or boots on the right plugs, because i know i made that mistake and had to look at a friends I6 to get it back in the right order becuase i mixed them up while changing the plugs.
BenBB is offline   Reply With Quote
Old 03-08-2006, 08:28 AM   #18
flykr2s
I too fought the rough engine idle and shimmy and shake for over a year. I virtually replaced everything on the engine in the way of sensors, wires, plugs, dist cover, rotor, motor mounts, etc, etc.... I was at my witts end and had just about given up. The only thing I did not replace was the coil and that was because it tested good with the ohm resistance test. Well, this past weekend bought a new $36 coil and replaced it. My Jeep now runs like it just rolled off the showroom floor. As a matter of fact, it has not ran this good in years. I have 235,000 miles and hope to get another 235,000 out of it......Tip of the day: REPLACE THE COIL.
flykr2s is offline   Reply With Quote
Old 03-08-2006, 08:44 AM   #19
dksob81
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Well in this case thats an expensive job, It has a COIL OVER PLUG DESIGN, which uses 6 Ignition Coils (Coil Packs), which are up around $130 each.
dksob81 is offline   Reply With Quote
Old 03-13-2006, 08:13 AM   #20
FourPointZero
FourPointZero's Avatar
I am running Bosch Platinum +2's. It runs exactly the same as the stock champion plugs. It there are any issues though I will just switch them out and send them back to bosch for my money back since they are guaranteed.
2001 JGC Laredo FourPointZero
K&N FIPK/Flowmaster 40 series
FourPointZero is offline   Reply With Quote
