Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-09-2014, 11:18 AM
92GSXguy 92GSXguy is offline
Re: 1g or 2g head gasket?
Well yes and no. The torque specs I used were wrong so that could be one factor, and the valves don't hit I hooked it up to the computer to see, but that is for the tip, I'll make sure to clean the surface of the block of all dirt and stuff to make sure of no leak. But I'm not sure if I should get a thicker head gasket or not.
Old 10-09-2014, 10:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
Usually you end up with oil in the coolant. It's much more likely, since oil pressure is higher than coolant pressure. Condensation can turn the oil to shit but it will clear up the first time you get it good and hot for a while. In other words, are you sure there is really a problem, before tearing into it again? A compression test will also tell you something. Usually if it's good, the HG will only leak under boost, not idle and cruise.
I don't know what's available for thicker DSM gaskets, all of the ones I have used are 0.054 compressed height.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
The Following User Says Thank You to kjewer1 For This Useful Post:
92GSXguy (10-10-2014)
  #18
Old 10-10-2014, 09:52 AM
Well I found a head gasket that is .32 thick. And it didn't clear up and it's been a week, plus it happens during idle.
Old 10-10-2014, 09:59 AM
And the coolant is in the oil, when you pull the dipstick it smells like oil and coolant.
