Old 04-11-2003, 10:25 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
Originally posted by freakray
I thought it may be worth mentioning, the Hasegawa kit of the Stratos I built came with the narrow body and additional parts to widen the rear fenders.
I don't know if that little bit of knowledge is worth knowing?
Ray
That is good info, now everyone can decide which one to build, full detail or curbside, wide or narrow.
Old 04-11-2003, 10:37 PM
freakray freakray is offline
AF Modelrater
Here is a contents photo from the Hasegawa Stratos, as you can see the body is the narrow and the additional flares are on the parts tree.
AF User Guidelines
Old 04-14-2003, 07:11 AM
bigfrit's Avatar
bigfrit bigfrit is offline
Thank you guys!
also , another little info on the kit ; the ligth can either be built up and down, and you can build the stardale version from the rallye kit , except for the Stratos insigna's and the lancia name tag on the back .
I for one , will be, and am making this one here , only a few built in this colour ; sorry , it 's the crappiest pic I could find !
olivier
Old 04-14-2003, 08:26 AM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
That is cool, does it come with engine of any type or is it strictly curb side.
Old 04-14-2003, 08:30 AM
AF Modelrater
Which kit are you referring to?
Read through the thread and I believe your question is already answered.
AF User Guidelines
Old 04-14-2003, 08:41 AM
freakray, your kit.
Old 04-14-2003, 08:42 AM
bigfrit's Avatar
NS :
the rally stratos's are all curbside, except for a blue one (rallye du Chardonnet -correct me If I m wrong ?)
olivier
Old 04-14-2003, 08:51 AM
Veyron's Avatar
Smile
Fujimi = engine
Hasegawa = no engine
Old 04-14-2003, 08:53 AM
THANKS freakray cause it looks as if I will be ordering the fujimi with the engine from HLJ. Now I just have to wait forever for the backorder.
Old 04-14-2003, 10:25 AM
mel79's Avatar
mel79 mel79 is offline
It's probably not important for most of modelers, but width of Fujimi and Hasegawa kits differ quite much. I don't have them here right now, but if I recall correctly they are both the same length, but Fujimi Stratos is almost as wide as Hasegawa's kit with wide body parts attached.
To me they both look right enough, but if you build more than one Stratos, then you should built all of them from the same manufacturer.
-Mikko
Old 04-14-2003, 10:35 AM
I just ordered from HLJ the following kits.
Lancia 037 Rally 1984 (no Engine)
Lancia Stratos Chardonnet (Yes Engine)
Lancia 037 Rally Detail Photoetch set
Can't wait ! :frog:
Old 04-14-2003, 10:56 AM
AF Modelrater
I have this 037 kit and I could swear it has an engine, I will check tonight when I get home.....
AF User Guidelines
Old 04-14-2003, 11:02 AM
You know I wasn't sure if it did or not, I thought I saw a thread that someone had done this one and it had an engine, but I don't think the hatch opened on it. I found it here it is http://www.automotiveforums.com/vbul...ghlight=lancia
Old 04-14-2003, 11:12 AM
AF Modelrater
You would have to make the hatch opening yourself, since you are correct that it does not open, but there is an engine that is visible through the glass in the rear.
AF User Guidelines
Old 04-14-2003, 11:15 AM
I don't think I am going to do all that modification because I am a newbie at this, but I hope is looks good through the glass like the 360 modena engine does.
