#16
Re: Radiator cooling fans are on all the time
If you disconnect the ECT the fans will run on high all the time probably for safety purposes.
#17
Thanks once again for your advice bnaylor3400. I think it is starting to make sense. I still want to wait until it acts up to replace it. As a learning experience I want to know for sure that is the problem. If I replace it before it starts to act up I will never know if that was indeed the issue. I think it might be though. I still say they wanted to replace the thermostat as an "add on". It seems to be working as designed.
#18
the temp sensor is mounted on the side of the radiator below the fill cap...its tough to see...mine used to set off the fans alot....i went to a pickapart junkyard and got a good one instead of paying big bucks from gm and it solved the problem...ps i believe there are 2 temp sensors in the system..1 on the radiator and the other on the block somewhere..?? good luck
#19
![]() First off that is not what the GM Grand Prix service manual shows. To test what I am saying, disconnect the ECT and the fans should come up in the high speed position for safety reasons. If you disconnect the electrical connector at the coolant level sensor it won't do anything. It won't even cause the fans to come on or turn on the coolant warning light. The coolant warning light needs a ground applied to turn on. However, both sensors may trigger the coolant warning light when conditions are met like low coolant level and/or overheating.
#20
I agree with Bob (bnaylor)that even though the ECT is checking ok on the bench, it may be breaking down under exposure to heat. I would change it if it acts up again, and if you haven't changed the T-stat within the last year, do it too while the cooling system is open. I change my t-stat every spring as regular maintenance(while checking cooling system for sludge and dirty coolant). Most people don't realize that a T-stat doesn't just open and close once. It can open and close (partially) 10-15 times per minute to properly regulate coolant flow and temperature. The bi-metal spring takes quite a beating, and can become slow or weak, restricting flow, not completely closing, or not completely opening. This could cause many problems, like weak heater output, running hot, etc.... Just my
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#21
sorry screwed up-- your right-- what it did (coolant sensor) at the time was allow the temp to go to near the redline on the dash temp gauge...this happened a few years ago forgot the specifics of my story..sorry for confusing you..
#22
sounds to me like whoever flushed the rad might have got debris on the end of the coolant temp sensor, u can try to remove it and clean it if NOT replace...should solve the problem....
#23
New update 3/9/06---
Replaced the coolant temperature sensor. Torqued it down to spec found in one of these posts. Although tempted, I did not use teflon tape, per another thread due to the NPT threads. Hooked everything up and fans still were on. So was the SES light. I did notice that the temp gauge was reading warmer then before, but well within limits. Took it to Autozone to read codes. Code read PO128-- Coolant temp always low. I told them to clear it and they responded that they couldn't due to emissions laws now. I decided that it would be worth while to rent a code reader while I was there and clear it. Once I did the fans went off. That was yesterday. Today the car came home and the fans were on again, but no SES light. Hooked the scanner up and same code popped up. Cleared it and fans are off. Started scratching my head. The book with the code reader said to check thermostat, it could be defective. I thought it was working, but now I don't. The first thing I noticed is that the upper hose was hot, but the lower hose was cold, and so was the radiator cap after 25 minutes of driving. It does not seem like it is circulating. So my thoughts are that it works once in a while, and the fans turn off when the PCM senses the correct temp. It gets stuck closed and the PCM reads cold temps, and throws on the fans for fail safe. Could this be right? Could it really be something like this that I should have originally checked for? My other thoughts are that some Dexcool sludge got built up in there, or when I had the flush done it all collected in there. So the way this car is set up, with the 3.1L, what do you think? There was no build up on the old Coolant sensor. Looked like new. Is there any other tests I should do on the thermostat? Thanks again for everyones help. I am just trying to figure things out. I hope this is coming to an end. At least I am learning alot about my car!! |
#24
Could it be that coolant level sensor mentioned above? I believe if the thermostat was stuck closed it would overheat very quickly and blow steam. May only be opening partially.
#25
Oops-- actually I meant to say stuck open. That way it is in a constant loop and doesn't have a chance to build up pressure or heat.
#26
#27
Is there an in car test I can do on the thermostat? I don't want to rip it out until I know for sure. However searching other posts seem to point to a bad thermostat also.
#28
#29
Re: Radiator cooling fans are on all the time--(hopefully) Final reply
Good morning,
Sorry I did not get back with the fix. After guessing for so long I believe I finally have it fixed. All it turned out to be was a bad thermostat. It was not allowing the car to get up to temperature. The computer would sense that the reading was wrong for how long it was running, and would throw the fans on to protect the engine. I now have a new thermostat and temp sensor (just in case) installed and it has been fine for two weeks now. I would like to especially thank bnaylor3400 for his time and guidance. It is users like you (and many others) that make me happy to use this board. birdboyd |
#30
