| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
#16
Re: Z32 Headwork
Jim Wolf's "Mild" cams are stock cams with reground lobes, they run about $500-600. However you do have to turn in your old cams to them or they charge an additional $400. Provided you have a reasonably good set of stock valve springs you should be able to pop these right in.
Jim Wolfs 400 series (the 400 and the 400+ cams) are ~$970 and are new cores ground to two different specs, the 400+ slightly more agressive. These cams require stiffer valve springs. They also carry the 500 series cam that is designed for maximum top end power. Z1 doesn't produce any cams, they sell Jim Wolf cams. A NA Z32 with a set of test pipes and a cat-back generally doesn't see any performance gains from a set of headers. Given how much of a pain in the ass they would be to install go ahead and skip this one. Extrude honing invovles straping the piece to a machine that takes abrasive jelly (think jello with sand in it) and forces it through the intake manifold at high speed. This allows the entire interior to be polished up without cutting the manifold apart and has the added benefit of replicating the flow of air through the manifold for the most efficient path. There is some variations in how it is done but thats the general idea.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo ![]() Warning: Objects in mirror aren't as fast as they thought they were. |
#17
Re: Z32 Headwork
yes, looking back at a few sites. some of them have misguided information. i was actually confused on the situation with the JWT cams. Z1 calls the reground cams the 100 series while other sites like Ztuner.com call the Mild series the reground stock cams and the Wild ones the 400 or 500. maybe i should email them and tell them they might want to further explain. i remember another website being even more confusing.... http://ztuner.com/engine.php anyways, broke...i already tried to explain to him everything you just said. he thinks he is gonna see more HP than a stock TT and i tried to explain to him that he isnt gonna see those kind of numbers but i think he is on a mission to prove me wrong. check it out here: http://www.automotiveforums.com/vbul...d.php?t=520627 BTW: i swore Z1 was using an outside business in their area to reground the stock cams and they were selling them for $400 or so. i was looking at getting a set and saving a little money.
ZedEx Crew Member #4
#18
Re: Z32 Headwork
#19
Re: Z32 Headwork
The bottom end is probably going to be a pretty basic rebuild. I might see about having some balance work done or look into some different rings, but otherwise there won't be anything really special about it. I'd like to punch it out to 3.2 or so liters, but that's just too expensive. Contrary to how my previous posts may sound, this really hasn't been a high budget build. We're getting great deals on the machine work just because of a working relationship that some of my family has with the shop. I've been working on getting the most possible for my uncle by utilizing available resources, but I'm also trying hard to convince him that it's worth stretching a bit so he can end up with something really unique. Generally speaking, he isn't really a hot- rodder, so my arguments don't always get the greatest reception. Since it is his car, though, I don't push too hard. On the other hand, the best part of this is all of the experience I'm getting from tearing down his car and rebuilding it. I can't help but feel like the idea of converting my own car is becoming more and more tempting. If I was to go out and find a turbo in as nice a shape as my NA, it would cost me more than the four or so thousand it would take to convert mine myself, right? Hmmmmm. Then again, maybe I'm getting way ahead of myself. I better just concentrate on seeing if my uncle's Z will actually RUN when I'm done with it.
Fun times at the Auto X...
#20
Re: Z32 Headwork
as for your uncle...maybe he could put the rebuilt units on Ebay and see what he gets for them. or you could just set his boost at about 18psi and let him destroy them fast. also, rebuilt units are very rarely done absolutely perfect so they do not tend to last that long. i would also consider Wiseco Pistons in the bottom end. for the extra machine work and the rather cheap price of the pistons it is a well worth upgrade. i would not rebuild a bottom end without them. these can withstand so much more abuse and detonation than the stock cast units. making for a much stronger engine. you could also have the stock units cryogenically treated for further strength. ARP rod bolts, Main studs, and head bolts also can be very useful and not that expensive...rod bolts being the most important piece. just a few more ideas. good luck
#21
Re: Z32 Headwork
[quote=Broke_as_****]Meh, whatever creams his twinkie.
Take it easy buddy stop getting off by thinking about that shit. I dont know whats so hard to understand my dad will only pay for the shit that i mentioned. He wont convert it. So go a head be the big man and talk shit online. |
#22
Re: Z32 Headwork
lmao relax dude....
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
#23
Re: Z32 Headwork
#24
Re: Z32 Headwork
It may seem odd to bring this thread back up since it is starting to get a little old, but I just wanted to thank those who provided advice regarding the thread’s original question. I just got my uncle's car finished up, and, after a few initial teething problems, it's running great. We did end up using forged internals, but for the most part it's running on mostly stock parameters. I really tried to push the aftermarket turbo idea, but I never managed to get through to him. If my uncle decides to go further with this thing later, though, it's more than ready.
As far as the car's current performance goes, my butt-o-meter says we might be touching the high three hundred hp range with appropriate boost, or MAYBE 400, but I have my doubts. I do know this: we had a friend get out his 2000 C5 Corvette automatic convertible, and did a brief run from 70- 130ish (this was on a VERY desolate road). I set the boost at @14 psi, and from the get go, we put a pretty good walking on him. I'd bet it will run with a regular 6 speed C5 coupe without a problem, but I have my doubts about the car being in C5 Z06 territory. Everyone else who has ridden in the car thinks otherwise, so maybe I'm wrong. The 14psi setting is cheating anyway, though. I told my uncle that, unless he makes a few more modifications to the fuel system, he should keep it under ten psi. Perhaps I'm being too cautious, but I figure it's better to be safe than sorry. Anyway, I'll stop rambling now. Thanks again for everyone's advice.
#25
Re: Z32 Headwork
His fuel injectors and pump should be enough for 14 psi.
http://itsgotturbo.com/ Click "Dynos" then click on the individuals names for their upgrade lists and dyno charts and such. There is quite a few Z owners running 14-15 psi with no problems.
#26
Re: Z32 Headwork
hey k3 where do u have to travel to get your engine work done? your not talking about ultimate Z are you ? thats a long ways from you , i heard the owner of that shop is selling is TT beauty for about 10 - 12k its pushing somewhere in the neighborhood of 600hp too
![]() ![]() Past Z Car Crew[The Enemy Of Your Enemy is Your Friend] >>Keep Your Friends close : But Keep Your Enemies Even Closer << |
#27
Re: Z32 Headwork
i have never seen the owner's car nor do i know anything about it. that is a very cheap asking price for a Z shop's owner's 600hp Z32TT.
#28
Re: Z32 Headwork
When I finally get a turbo Z of my own, though, I will definitely keep your suggestion in mind. I would be willing to take greater risks with my own car. (All in the name of science, of course.) Then again, if you, along with any of the other members here, feel that 14 psi really is a low-risk, LONG TERM option, feel free to provide more input. I might put some more research into the idea and consider it further.
#29
Re: Z32 Headwork
Extremedrift: I was just curious about the motor in your sig. Is that a real photograph? If so, what is it from? Maybe Hyundai freight ship?
#30
Re: Z32 Headwork
