Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-21-2006, 07:26 PM
flipster30 flipster30 is offline
Re: new cam for 305
could anyone give me an idea what kind of power gains i can expect from the rv cam and removing the ac condenser and all. and also removed air pump and all components.
Old 02-25-2006, 06:21 AM
Thumbs up Re: new cam for 305
well finally figured the problem out we tightened the valve springs according to the instructions lunati gave us and they ended up being way too tight my uncle adjusted them while running said thats how he used to do it when he was a kid. now it is runnin pretty good and im glad to have it back i missed her. ive had to drive my ole ladies 2004 nissan sentra good car but too small for me. well i am 6"1 and 300 lbs so i dont fit in there all that comfortably. i do think that this site is a great place to get some help and want to thank everyone for trying to help.
Old 02-25-2006, 10:06 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: new cam for 305
You over-tightened the Rocker Arms. Yup, that'll do it. When I'm putting a small block Chevy together, my rule of thumb as far as valve adjustment is to tighten the nut on the rocker while spinning the pushrod between my thumb and finger - when the rod stops spinning, I'll tighten the nut a half-turn further in. I'll do this with a certain number of valves, then turn the crank 180 degrees and finish up.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-25-2006, 05:12 PM
TommySS TommySS is offline
Re: new cam for 305
Wow, learned something new. Thanks !
Old 02-25-2006, 05:45 PM
silicon212's Avatar
Confoundingly Lucid
Re: new cam for 305
OOps! Turn the CAM 180 degrees - one full revolution of the crank.
:O
