Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 03-07-2006, 08:11 AM
blh1960 blh1960 is offline
Re: Timing belt change
I have done several t-belts. Never on a Isuzu product. What I like to do is get #1 piston at tdc and line up the tdc timing mark. I then like to take some fingernail polish or whiteout and make a identifible mark on the camshaft gears and crank pully that can be line up again. Then disassemble and then you can get it where you want it. I take a straight edge between the cam bolts and mark the inside (9:00 and 3:00 O clock for DOHC). Mark the crank at 12:00 O clock. Never had any problem doing it this way. For SOHC just straight edge between bolts and mark. Most of the time you do not even need a manual to do it this way.
Old 03-19-2006, 11:37 PM
mrmax13 mrmax13 is offline
Originally Posted by mytrooperhatesme
Thank you so much for your reply. One question for you...You lined up the two camshaft pulleys with their marked positions...did you line up the crankshaft pulley with the 0 timing mark?
Again thanks for your reply.
Mike
Yes. I had to search forever for the little damn mark for the crank. Turned out it was right next to the thing. I lined up the marks exactly the way the books said.
Sorry for the late reply.
Mark
Old 06-14-2006, 02:19 AM
K6SJC K6SJC is offline
Mark
I just finished mine and the mark on the crank is hard to find, the chilton book did say where to look. Read haynes book and its more detailed and it tells you right were it is. Now my 93 trooper S runs like a champ.
Old 07-06-2006, 01:42 PM
eb4i eb4i is offline
Did the tb R&R go without hitch? My wife's 2000 Trooper now has 100k miles, so it's time to replace the tb. I've done this on Mitsubishi and other cars but never on an Isuzu. So I think I know what I'm doing, but the real question is, do I need a repair manual that specifies all of the details that are not obvious? Comments from anyone please.
