#16
Re: Towing question
[quote=kmschna]Has any of the responders to the oringinal question 'actually' pulled this large amount of weight with a 1500???
QUOTE] I have towed quite a bit of weight behind my '00 Silverado Z71 1/2 3/73 gears. It will tow just about anything.. the thing I was more worried about was bottoming out. Stopping is an issue as was mentioned.. don't stay too close to anybody.. Going up hills is a choir. I was only able to do 45mph up the mountains. If I had the 4.10 gears, I would have been able to get up the hills better. I was pulling fulling loaded 6x12 Uhaul Trailer + and fully loaded bed and extended cab. estimated weight was about 7000lbs. But I do not do this all the time to justify getting a 3/4ton truck. But since you will be, then get the bigger truck
![]() ![]() 2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running. |
#17
Re: Towing question
[quote=silverado122775]
'02 2500HD 6.0/4.10 Air Lift bags, 175 psi onboard air |
#18
Re: Towing question
I guess what I am saying is that it will move just about anything.. but again.. we are talking about safety. the things I mentioned above are the things you have to worry about if you are going to tow something heavy continously (several times a year). That's all.
#19
Re: Towing question
I agree that your situation does not warrant a larger truck as your load was unusual, but if the original poster is going to tow the trailer on a regular basis, he should consider a bigger truck. Well said.
#20
Re: Towing question
Thank you.. I appreciate the compliment..
Hard to tell if someone is being sarcastic...LOL
#21
Re: Towing question
I personally think braking is not an issue between the 15oo and 2500 series unless the truck is actually carrying the load in the back. By law any trailers weighing over 2000 lbs must have it's own braking system. I know when I haul the TT I own @ 8000 lb, breaking capacity of the truck is not a concern.
#22
Re: Towing question
Not sure about you, but those brakes on the trailers are designed to keep the trailer from swaying when you stop.. they are not used for actually stopping the trialer.
#23
Re: Towing question
There is no way any 2500 series truck is going to safely stop a 8000lb trailer on it's own, period. And besides, towing one without trailer brakes is against the law. |
#24
Re: Towing question
IF you are hauling or towing weight that is marginal or even questionable you should consider how well you can stop, and how well the truck handles the weight. There's far more to it than being able to move the load on flat ground. |
#25
Re: Towing question
Re-read my post! The question is about trailer towing/breaking. The 2500 series has a definated advatage in towing and load carrying ability but nothing in breaking when hauling a properly equipped trailer. The heavier suspension, braking, and larger engine of the 2500 series make a better tow vehicle but does not make for much if any better stopping vehical when the trailer being towed has a operational secondary braking system. As any reputable RV dealer.
#26
Re: Towing question
Have you ever had your brakes burn out on you? you will if you are towing anything with a load. Let's say you are driving down a hill with an RV (as you mentioned) in a 1500. you see something ahead that is requiring you to stop. you hit the brakes in an attempt to stop. Opps the "auxilary brakes" do not work on the trailer. now you have to rely on your front brakes of your 1500 pickup. Opps your brakes start to smoke because there is too much load on them. opps you just ran into the car in front of you. damn.. now whose fault is that?
Now if you had a 2500 or higher, your brakes would not fail on you because they have better stopping power.. Brakes make all the word in differance when it comes to towing. NOt sure about you, but I would not rely on the tailer brakes, I do not care if it is the law to have them, doesn't mean they have to work properly.
#27
Re: Towing question
And please don't spell it "breaking" when we are talking about the load capability of the 1500 as there has been a lot of broken frames at the rear section on the '99 and newer half tons when they haul more than they are designed for.
#28
Re: Towing question
