Old 02-10-2006, 05:15 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Still throwing code 36..
Originally Posted by aznb0ipnoy
Yes they would....THeir 1.6L v-tec motors make 165hp, their 2.0L v-tec motors make 200hp. American cars are very inefficient....and lack power per liter...
Power per liter??? 100% ricer argument.
Learn all cars before assuming things.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 02-10-2006, 09:51 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
hey, No i didnt reset the ECM, but after i set up the new MAF, the error code DID go away...it just came back. i did however reset the ECM later, to see if it would go away...and it just came back. well the code went away..for some reason..because...i got into an accident and stuff and yeah..
the error code went away O_O. but..i didnt do anything.
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 02-11-2006, 02:00 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
If the code went away from the ecm's memory without you reseting it. Then you either have a faulty ecm/a loose prom/faulty ground..
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-11-2006, 02:06 AM
well, the code still MAY be stored, but it doesnt have the CEL on anymore..? while i had the fender off, i did make a couple grounded wires tighter.
Car:
285's in the back
all else = STOCK.
Old 02-11-2006, 02:10 AM
FormulaLT1's Avatar
Fight the powwa!!!
You need to reset a ECM whenever there is a code in the ecm's memory that has been taken care of. If you tried two MAF's the only two other possible causes are wiring or ECM. It is also possible you have a bent prong on the harness that is not making contact. I have had that happen before.
Old 02-11-2006, 08:45 AM
tri-power's Avatar
tri-power tri-power is offline
If the code is still coming up, you may still have a bad MAF relay like I posted b4. Many time in those cars, replacing that should turn off the code.
Old 02-11-2006, 09:17 AM
maxwedge maxwedge is offline
A990 racer
Thumbs down Re: Still throwing code 36..
Ricer indeed, 200 hp at 8g's and no mid range torque, good luck!
