Old 02-09-2006, 02:18 AM
strunch strunch is offline
Re: 99 Astro Van check engine light but no code
yeah..i will use dry gas...thanks for that.
I like how my repair manual tells me how to test my MAF sensor...
it says to hit it with a screwdriver...i like that...that is one high tech instrument i do own.. a screwdriver.
Old 02-09-2006, 08:45 AM
xtreme barton xtreme barton is offline
Originally Posted by strunch
.. I like how my repair manual tells me how to test my MAF sensor...
hahahahahahah that is pretyy funny
Old 03-09-2006, 08:04 AM
Unhappy Re: 99 Astro Van check engine light but no code
My van is doing it again! ...it hasn't started for a week now but this time the tank is full of gas and i put heet in it...maybe i will take the distributer cap off and look for moisture? Again, it happened when the temp was around 32 and when it is raining out or foggy and it sits for a few days.
Old 03-09-2006, 09:06 PM
old_master's Avatar
Advisor/Moderator
A tune up consists of AC Delco double platinum or iridium spark plugs; don't waste your money on anything else! Spark plug wires, distributor cap and rotor, fuel filter and air filter. Get good quality parts and do the job once! There are no adjustments to timing or idle speeds; they are done by the computer. In post #12 of this thread, you had spark at the coil but not at the plug. That indicates a problem with the cap, rotor or wires. Replace them all.
The P0102 code was set from starting the engine with the mass air flow sensor disconnected. After connecting it, the SES light should go out by itself, provided there are no other problems in the system. NOTE: To retrieve trouble codes, clear trouble codes, and/or turn the SES light off, all require an OBDII scanner.
